Car is studdering...
Guest
Posts: n/a
280zx turbo
When I first start the car up I have no problems at all. Once I get under about 15psi and full throttle however, the car starts to spudder and it runs very choppy.
It's been doing this for like a few days now, and I can't figure it out. I've run a bottle of injector cleaner, I've done a compression test, I've replaced my plugs with new ones, I've checked the wires and cap/rotor, all have less then 10k miles and are fine.
Anyone have any clues?
with increased boost you make the gap smaller right? when under increased boost the car will start breaking up with a larger gap do to the increase compression?
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
oh ok didnt know the whole story. what about the coil?
did you do a noid light test
