Enthalpy, Mattback.. question
Old Feb 19, 2004 | 10:21 PM
Jeff240sx's Avatar
Cpt. Negative
Default Enthalpy, Mattback.. question
What is keeping us from running o2 sensor-less? I've heard the ecu only has 16 fuel points (you'd know better than I would ), and so does an emanage. S-afc II has 12. Couldn't we drop the o2 sensor(s) and run off a fuel map? This should make tuning easier, because instead of the ecu adding/removing fuel, it should run on a flat-map, which is then adjusted totally by the piggyback.
Just an idea. Feedback, flames, ect are appreciated.
-Jeff
** This space reserved for someone else's witty quote **
Old Feb 20, 2004 | 02:51 AM
Chin's Avatar
MASTER BREWER:HOT TEA
I would think that non O2 sensored run cars usally also run of MAP sensor (Manifold Absoult Pressure)? if i'm not mistaken. But who knows
Old Feb 20, 2004 | 04:29 AM
Enthalpy's Avatar
TR Balla Donor Supreme
ok,
ALL modern fuel injection cars run an oxygen sensor. both MAF and MAP variaties.
the O2 sensor is usually used for what are called long and short term fuel corrections. short term is an instantaneous correction to the amount of fuel supplied, long term is a pre-calculated correction to the amount of fuel supplied. on SR's an KA's the O2 correction is only short term form the best of my knowledge. it is also only applicable to certain areas of the fuel maps. usually under light load conditions. also, the O2 sensor usually gets ignored during WOT. so, why do we want to eliminate the O2 sensor, it doesnt really hurt us.
Old Feb 20, 2004 | 08:15 AM
Jeff240sx's Avatar
Cpt. Negative
No o2 sensor saves me $5 on a o2 bung, and $80 on the damn sensor
-Jeff
Old Feb 20, 2004 | 02:00 PM
tampamax's Avatar
So what happens if you run on flat pre-programmed maps and then the whether changes dramatically? If the intake temp drops by too many degrees does that mean there is more air getting into the cumbustion camber cause it is more dense? If so then couldn't you in theory be running into the lean side tooooo much with colder weather. Also, what happens to an engine with the fluxuation in humidty? Is the o2 sensor just one of the imputs the computer uses in open loop to make adjustments for such things?
You don't like it? So sue me. Don't take me seriously though.
Old Feb 20, 2004 | 02:15 PM
Jeff240sx's Avatar
Cpt. Negative
The air intake temperature sensor and mass air flow sensors adjust for that. O2 sensors change the fuel based on a:f ratios.
-Jeff
Old Feb 20, 2004 | 03:20 PM
buck19's Avatar
Forever Broke Nissan
just upgrade to a realtime o2 sensor and scrap the analog sensor.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Feb 20, 2004 | 04:14 PM
MaxType 240's Avatar
All Around Maxed
$80 for an O2? I thought you were better than that. Universal Bosch for our cars run around $23. It doesn't come w/ the OEM harness connector but just splice and dice from an OEM one. You can also just splice in w/out the harness, it's one wire for heavens sake...
Jesse
Ings RSpec, Built KA24DET, GT3071R
VR-4 AWD/TT Winter Sled
