S14 Electric Fan wiring
my friend said he could get used ones for like 30 a piece.and if you have an open diff you will probably only need one dependine one how hardcore your getting in to it.At least when i go out i usually kill 1 tire and have about half left on the other.Or junkyards you could probably get a big 5 lug rim with a tire for like $12 or somewhere around there.
S14 factory fan? theres 4 wires (yellow, black, green & blue)
yellow and black are grounds
green and blue are powers
use any one combination (yellow and blue, green yellow, etc) and the fan will run on low speed
but use all 4 wires, and its on high speed. you can just ground out the yellow and black wires and then run the green and blue jointly through the relay and it will run on high. a relay has 4 posts on it. one is ground. one is trigger, and the other 2 are the actuall switched wires. the battery is connected to one side and the fans; the other.
when the trigger is powered (IG +), it energizes a solenoid that connects the switch inside bridging the power from the battery to the fans. the simple is best complimented with a thermostatic switch that energizes the relay only when the coolant temps need it.
RIP Tim. i miss you, buddy
Thanks for the info. I really appreciated that. Maybe you can give me a hand or show me what to do at D-Day.
Also big thanks to XAT Racing (casey) for renting me some tires! Looks like I'm in for sure
Hopefully Taylor won't forget to bring them
To Taylor and XAT
Hello!
Hello!
