emissions block offs
Old Jan 27, 2004 | 10:44 AM
dan's Avatar
dan
Get the fuck off my lawn
the tranny light could be just something that wasnt done since u can do auto to manual swaps and get away with it running fine but get a light. check www.ka24development.com to see if the electrical portion of your tranny swap was similar because i believe brians (the guy whose site that is) car has no check engine light.
the egr light will come on if ur egr isnt hooked up and working right. most likely the egr-temp sensor that is screwed into the little egr runners (alongside the 4 allenhead screws) in the intake manifold. its not seeing any "hot" exhaust gas (since its not recirculating anymroe) and flipping a code.
the only failsafes i can remember offhand that will cause the car to run in limp mode are if your maf sensor is unplugged or bad, and i believe the misfire detection might as well. knock sensor could too if it starts reading a constant knock maybe? but usually i think it just adjusts timing to keep the knock away.
Old Jan 27, 2004 | 01:07 PM
nismo180's Avatar
so, is it really worth taking the time to remove every thing? do you actually notice a power increase?
Old Jan 27, 2004 | 04:04 PM
RubberBerner's Avatar
Sideways Maffia
So which hoses on the intake side of a once need to stay, and which hoses can u get rid of?
NOBAMA!
Old Jan 27, 2004 | 04:33 PM
dan's Avatar
dan
the only hoses that are required IIRC are the ones for the iacv and the other valve that it's hardline leads to, the line from the manifold to the fuel pressure regulator. the line from the pcv valve can be vented to a catch can or just dumped (dont think thats tech-pass-worthy though) and the same goes for the valve cover blowby vent. if i think of any others ill try to remember.
and if u take things off things have to be capped or welded shut so u dont have massive vacuum leaks.
also the brake booster line is needed too.
Old Jan 27, 2004 | 06:43 PM
turkeyspot's Avatar
so anyway what all can i take off my motor. Taylor pulled all the b/s and the wiring that went with it, but i dont know if that solved the CEL problem.
Old Jan 27, 2004 | 06:49 PM
  #17 (permalink)
Sideways Maffia
and what hoses need to stay attached, and what ones can get the hell outta my engine bay?
NOBAMA!
Old Jan 28, 2004 | 08:34 AM
  #18 (permalink)
Angela's Avatar
That girl with the camera
Originally posted by Vapor
some people say yes, others no. I'm no big fan of it, but if it ain't broke, don't fix it. BTW, 96 was still obd2. OBD1 is 91-94
What about a '90?
Jake
[CENTER]
Photography :: AIM :: PicturesSay1word :: Facebook
Old Jan 28, 2004 | 10:59 AM
  #19 (permalink)
Sideways Maffia
90 is a SOHC and is pre-OBD to my knowledge, but u still need the MAFS connected.
REMEMBER: if the engine starts to show signs of struggle, reconnect it.
NOBAMA!
