KA-T not idling - need AICV
Old Dec 15, 2003 | 08:55 AM
MaxType 240's Avatar
All Around Maxed
Default KA-T not idling - need AICV
Idles fine w/ TPS disconnected. Cleaned the IACV (it was nasty) but now the ECU hits me w/ AICV error. Anyone have an AICV I can swap out and test with?
Also sounds like I have a vucuum leak somewhere inside the intake manifold jungle of lines. How much time does it take to remove the upper intake manifold? Can anyone swing by and help me check, time is my enemy right now... Seriously ruining my schedule
TIA,
Jesse
Ings RSpec, Built KA24DET, GT3071R
VR-4 AWD/TT Winter Sled
Old Dec 15, 2003 | 12:32 PM
RubberBerner's Avatar
Sideways Maffia
why don't you just block those lines off?!
NOBAMA!
Old Dec 15, 2003 | 01:01 PM
All Around Maxed
Um, i'd like to have dynamic idle for warm-up and air conditioning. I'm gonna go through the basics now:
See if disconnected MAF works/add MAF ground
Clean IACV/MAF harness connectors
Inspect plugs/wires/cap/rotor
Check injector connections
Check coolant sensor connections.
The little stuff kills me, thanks for heads up though!
Jesse
PS- Anyone have a soft copy FSM? I lost mine...
