found out the sr problem but dont know what to do to cure
Old Oct 23, 2003 | 06:21 PM
streetheatpittsburgh\'s s1's Avatar
Default found out the sr problem but dont know what to do to cure
the problem were finding is that there is fuel being pumped but the pressure regulator is not opening up to let it flow. and also there is no power going to the fuel injectors checked by volt and continuity tester. what maybe a cure. or a reason. thanks alot for the help everyone.
streetheat pittsburgh
Old Oct 23, 2003 | 06:46 PM
Epstein's Avatar
Retired
This sounds dumb, but make sure the fuel lines are hooked up to the regulator/rail correctly. The reg doesn't work good in reverse! The return goes on the regulator. The line with the filter goes to the rail. Maybe your filter is plugged up?
As for power, make sure the CAS is plugged in/working. My CAS plug was sticky; it looked like it was on all the way, but wasn't. That gave me a nice scare. haha.
Chris
Old Oct 23, 2003 | 08:17 PM
sucess. that was my problem the hoses were wrong. thank u very much for the info
and thanks to everyone else for the info aswell
