help buck19's 91 coupe is over heating
Old Sep 30, 2003 | 02:07 PM
Garage Battle's Avatar
i wanna go fast
rust in the radiator...what color is the freon? are you just low on freon?
If you havent replaced the t-stat yet then just pull it out.
seriously check and see if u got some rusty coolant...could have a clogged/blocked radiator with rust.
Old Sep 30, 2003 | 05:07 PM
Durdan's Avatar
No Ants Drift Member
hahaha rob
i ruv you
he has overheating problem. not ac problem
hahahahaha
i think you meant antifreeze
RIP Tim. i miss you, buddy
Old Sep 30, 2003 | 11:36 PM
i wanna go fast
Originally posted by Taylor Durden
hahaha rob
i ruv you
hahahahaha
jeebus. gotta stop posting within the first hour-two that im awake.
Old Oct 1, 2003 | 08:11 AM
Matt Vassallo's Avatar
lifelong learner
in japan coorant is called freeon
rest in peace tim.
Old Oct 3, 2003 | 06:52 PM
buck19's Avatar
Forever Broke Nissan
my fluid was a little rusty but not as much as i have seen others.
im going to swap out with another radiator and thermostat. plus drill a small hole through the thermostat.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Oct 4, 2003 | 04:04 AM
Durdan's Avatar
i dont reccomend drilling holes in thermostats. buy a new one. check your fan clutch, too. im sure its something simple
Old Oct 4, 2003 | 05:56 PM
  #17 (permalink)
buck19's Avatar
ok. found out my car DID NOT have a thermostat in it. fucking gay shit. bought a new one and a gasket for it. dremelled some deposits out. bought a fluidyne radiator for an s14 sr20 swap dealio and a moroso aluminium overflow tank. so i spent around $700 today. keep in mind mine is an s13
well the top brackets for the radiator dont line up as ive seen on many other 240s. im going to go to discount tomorrow and try and find a hose to fit. im sure someone has made brackets for for the fluidyne radiator.
oh yeah i didnt know the transmission fluid went into the radiator as well. so i had to buy at tranny fluid cooler. thats in and installed but havent pu more fluid in it. add $35 to that $700.
yay
can some one help me finish this. i have an angle saw, just need some drill bits and someone that has made brackets and installed sr20 radiators.
please help. so close to being fixed unless its a head gasket. anyone have a compression check tool. cant really spend too much more money for the rest of the week.
going out to play with the SRs tonight in my friends n/a civic. YAAaaay.
Old Oct 6, 2003 | 07:32 AM
  #18 (permalink)
buck19's Avatar
well i got some drill bits and a strip of 1/8" aluminum at home depot for the brackets.
im serious does anyone have a compression tester. i wont be able to buy one till next weekend, but i would like to know that i have a blown head gasket before then so i can get a gasket by the weekend.
Old Oct 12, 2003 | 06:04 PM
  #19 (permalink)
buck19's Avatar
just bought a black fal 220 fan for an s14 as well. ill post pics with the s14+ sr20 radiator and s14+ dual fan when im done.
i think its going to be a little interesting considering im going from a 2 prong to a 4 prong fan. ill make it work.
