2jz stage two
You might have to change your sig soon, looking good we'll probably both be tuned out to full potential around the same time. Hopefully I'll get my blow off valve on tomorrow 35r wasn't shrouded so I had to get one...
That is sweet Ed ,but I bet you be running way before me .I still a long way to go.
My shit still slow
618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
stock block ,more power coming soon ,stay tuned
Tuned by Alpha @ Induction Performance
My shit still slow618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
Oh I also need tires I'm back on street tires for now so spin spin spin
Hahaha I heard what you are saying Ed. also if you goin e 85 you need injector dynamics at least 1000 cc or any other 1600 cc injector brand ,a weldon fuel regulator to be able to keep up with higher base pressures .at least 8an feed and 6 an return (make sure the hoses are e85 compatible they have to be teflon coated) also the fuel rail have to be anodized on the inside cause e85 is very corrosive.dual pumps (you got that cover). Amazon hoses will be your best friend and or this guys they got pretty decent prices and it take like a day or two to get the stuff http://racepartssolutions.com/categories.asp?cat=2
My shit still slow
Haha I was thinking the same thing . Chris how the car running? Hopefully soon I be able to keep up with you guys.
My shit still slow
Finally some reals updates .This is after 6 hr of work .Hopefully tomorrow I can finish the downpipe and dump tubes .to take them to ceramic coat. Here you go.
My shit still slow
