The correct way to build an s14.
you didnt happen to keep the card board cut outs?. should be able to make a few "kits" from those to sell
I'm sure some one with a CNC machine could do it, but I couldnt even transfer the stencils side to side in my case.
Up date: Fuse box is fucking impossible to hide. So its going to sit pretty right behind the headlight pan.
what size are your front wheels again? and how low are you gonna be going? the tubbing seems to be a really good/cool idea. when i start building my next "project" car i want to do some custom fabbing to the front to run the 17x10 fno1r's, then i will be 17x10 all the way around! that will be nice.
This weeks progress;
Seam sealed the entire set up and started a little filler work.
Sealed the under side of the car and sprayed it with bedliner coating stuff.
S
