DSM link?????
just curious who all has it and how they like it, as soon as i can find a 95 eprom ecu i'm going to get it, also if anyone has it in a 97 to 99 car can you explain the whole deal with switching the fireing order or whatever the hell you have to do to get it to work
I have it
I like it it is easy to use, not as complicated as the aem,haltech or motec, but doesnt have all the bells and whistles the other systems do
I have a 97, all you have to do it swith the plugs on the coil swap 1&2 & 3&4
www.dsmlink.com
it tells you all the info on there. You will also have to invert the cas in the prefrences.
it gets my
Also eric has it, i will let him give his .02 as he has had it alot longer and then i have and has more experience and the times to back it up. Version 2 should be out shortly which will be a moderatly cheap upgrade
www.dsmlink.com
it gets my
try this place for the eprom ecu if u cant find one of anyone
it is where i bought mine and they took my 97 as a core so you get some money off
foreign auto computer
9403 n. 14th st.
tampa
813-933-7559
800-241-6689
www.ForeignECUrepair.com or www.RebuiltECUs-ECMs.com
good luck
btw-nice looking 2g very clean
9403 n. 14th st.
tampa
813-933-7559
800-241-6689
good luck
