question...
Old Apr 1, 2003 | 07:37 AM
PreludeXTC's Avatar
Senior Member
Default question...
I installed a greddy type s bov on my gst a little while ago but then i notice that in 2nd, 3rd and 4th gear after 3500 to 4000 it feels like the car hits a fuel cut off and Ive looked pretty much everywhere to find this answer but couldnt find it and no one seems to know....thats the only mod i have done to the car but whats weird is that when i tried an hks sqv it did the same thing so i put my stock bov back on and it worked fine but it does feel sluggish at high rpms......
and please if you dont have anything contributing to say....dont bother replying
Old Apr 1, 2003 | 08:14 AM
Skillionaire's Avatar
Nobody
Hey man. I believe i met you a few nights ago, at fowler and nebraska. I had the 1G talon. I would recommend checking the basic stuff first such as spark plugs before anything else. Since you said the car breaks up at high RPMs even on the stock BOV. Run down to discount auto and pick up some NGK plugs (BPR7ES part# 2023) if you havent already. Probably wanna look into some new plug wires eventually also. Id still say remove 1 or 2 honeycombs from the MAF, just dont butcher them so that you cant put them back in if you have a problem.
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Apr 1, 2003 | 08:21 AM
PreludeXTC's Avatar
Senior Member
Hey whats up man...yea i remember....i have ngk spark plug wires on there right now...i want to try the honey combs but i dont want to mess up and butcher it lol.....i ran a diagnostic and it said air fuel metering malfunction and system idle control malfunction......so i was thinking it was the sensors.....
Old Apr 1, 2003 | 08:24 AM
Nobody
well, doing the plugs if you havent already is a must. Just unscrew the little cover that holds the honeycombs in and pull them out gently with tweezers or needlenose pliers. Its pretty straight forward
Old Apr 1, 2003 | 08:40 AM
Mike@RM Performance's Avatar
Owner-RM Performance.net
It is better to use a pencil eraser to work the honeycombs out
**do not remove the center one, start with one side or the bootom, Do not remove more than one, i wouldnt even recommend doing that at this time. It is totally your call
Mike
2005 Evo RS
WWW.EVOwned.COM
Old Apr 1, 2003 | 08:56 AM
PreludeXTC's Avatar
Senior Member
How come??
Old Apr 1, 2003 | 09:30 AM
Sneakin Deacon's Avatar
PSSHHH x2
you'll run leaner...too lean = problems
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Apr 1, 2003 | 10:05 AM
Nobody
Well from what ive experienced, every car reacts differently. As long as you dont go nuts and make it so you cant reverse the process, i dont see any problem. Especially at stock boost
Old Apr 1, 2003 | 10:21 AM
PreludeXTC's Avatar
Senior Member
do you think (atmosphere) venting affects that?
Old Apr 1, 2003 | 10:35 AM
PSSHHH x2
are you plugs properly gapped to about .030?
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
