i need dsm info quick
Old Mar 17, 2003 | 05:38 AM
DSTGST's Avatar
factory turbo charged car
Default i need dsm info quick
i have a 94 gst 5 speed.
the turbo coolent line sprung a leak so i changed it but when i was changing it i broke the radiator fan switch. so i went to the mitsubishi dealership and bought a new one. i installed it and turned my car on and let it warm up and the temp gauge just goes right past the middle part and looks like its going to overheat, then i shut it off. i have absolutly no idea. im asking for help because this might have happend to someone else and they might know what to do. please help and thanks fellow dsmers.
thanks from mike
Old Mar 17, 2003 | 08:29 AM
Mr 2's Avatar
New Member
got coolant?
Old Mar 17, 2003 | 09:02 AM
4ged4G63's Avatar
do you have the fan electrical connector plugged in? Simple but if its not plugged in the the fan won't kick on and your temp needle will sky rocket.
Old Mar 17, 2003 | 04:40 PM
Skillionaire's Avatar
Nobody
new thermostat maybe...mine did that in traffic and i cracked my radiator
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Mar 17, 2003 | 05:50 PM
DSTGST's Avatar
YA I JUST FLUSHED ALL MY COOLANT AND FILLED IT UP WITH NEW COOLENT EVERYTHING IS ATTACHED, AND MY THERMOSTAT IS FINE, BUT I THINK I BLEW MY RELAY. AN OTHER OPINONS THANKS MIKE
TURBO IS THE ONLY WAY TO GO. IF YOU DON'T HAVE ONE GET ONE. HA HA
ALSO FRIENDS DON'T LET FRIENDS DRIVE STOCK.
Old Mar 17, 2003 | 05:55 PM
PiercedJD's Avatar
so jumper the relay so the fans turn on with the ignition switch.
Old Mar 17, 2003 | 08:02 PM
138MustangGT's Avatar
IF HE JUMPERS THE RELAY IT WILL OVER COOL THE ENGINE. The fuel maps in his ECU will cause timing to retard like crazy if the engine is running too cool. AFAIK, on a 1g (I know you're 2g) the timing will retard almost ten degrees if coolant temp is significantly too low.
you'll lose some hp for a while, but you wont hurt anything... you CAN jumper it until you can find the REAL solution.
-Shawn
(2 posts my a$$, I posted plenty in the autox section 3-4 years ago... GOD, i go on deployment ONE time and you reset my counter? lol)
Old Mar 18, 2003 | 04:01 PM
PiercedJD's Avatar
funny, because both of my fans are hardwired to come on with the ignition, and I have no timing problems to speak of.
seeing 18-24 degrees timing at wot on a 90.
I have plenty of logs to prove it, what's your e-mail? I took the liberty of logging coolant temps, intake temps and timing so you have plenty of variables to compare against.
Old Mar 18, 2003 | 05:36 PM
Mr 2's Avatar
New Member
I run my fans all the time and have no thermostat, damn I guess that is why I am slow
Old Mar 18, 2003 | 07:26 PM
DSTGST's Avatar
i hard wired it to make sure it was the relay so i got a new relay and that didn't fix it but now they work so don't ask me my dsm has a mind of its own. but i need to fix it for real not just hope it works. but if you have any more ideasill take them. thanks
