Power Problems, need help asap
Old Mar 14, 2003 | 07:23 PM
Sneakin Deacon's Avatar
PSSHHH x2
Default Power Problems, need help asap
alright, well i havent driven my car since monday afternoon (today is friday) i was driving down the interstate at about 3k and look at my guages and stuff an everything looked dimmer then usual, played with the knob, nothing happened, barely got dimmer if anything. so i pulled off and when i made the turn and got on the gas coming out of it it was sputtering badly (figuring not enough power to spark injectors) and my EGT's rose past 1200*C!!! (i dont know if this was an actual reading because anytime i pressed the brakes or used a turn signal you could watch the guage bounce up when the light came on and drop when it went off) and i ran to the nearest gas station as fast as i could, checked my ALT belt, looked to be nice and snug, checked everything else i could at the time and it all looked to be in good order, had hard time starting the car but made it back to the interstate and i couldnt keep it at 2500 in 5th without feeling it missing, so i cut my lights, radio and guages and it quit but i turned my cautions on just for safety. but watched them fade quite quickly and then the car just stalled outright, i let it roll approx 1.5 miles and put it in 2nd and popped the clutch and got it going again and limped it back to my dads house. so i have narrowed it down to alternator went out, or battery is dead(dont see how, it worked just fine last time i drove it but possibly)
if anyone has any other suggestions they are greatly welcome, i have a long venture next weekend and cant afford to break down in BFE.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Mar 15, 2003 | 05:10 AM
91TSI_AWD's Avatar
Resident Galant Guy
sounds like alternator. If you can jump start it. and let it run for a little. get a voltmeter across the battery to see if the alternator is charging it. while running you should get more then 12.6 to about 13.2. I should have an alternator around. ill let ya know.
Mike
95 Lancer GSR
93 300ZX 2+2
Old Mar 15, 2003 | 06:02 AM
PSSHHH x2
alright, ill take it, i might be able to run the car down there, ill bring another battery just in case.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Mar 15, 2003 | 12:22 PM
DSTGST's Avatar
factory turbo charged car
i had sort of the same problem and it was the 80 amp altenator fuse it took me forever to find that was it but now there are no probs. good luck and make sure your terminals are ok. thanks
TURBO IS THE ONLY WAY TO GO. IF YOU DON'T HAVE ONE GET ONE. HA HA
ALSO FRIENDS DON'T LET FRIENDS DRIVE STOCK.
Old Mar 15, 2003 | 01:02 PM
PSSHHH x2
fuse is fine, pretty positive its the alt.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
