On to the dark side.
Old Jun 15, 2011 | 02:16 PM
5.9FOX's Avatar
Default On to the dark side.
Well after many months with my 351 fox body I decided I was bored with it wanted something a little more complicated to play with that still had a strong base to build off. So I went with an import (before I saw how stupid exspensive they are) for the complicated part, and a dsm 4g63 motor for the strong base to build. so I got this 93 egale talon tsi funwd. its a total pos but it was cheap so what ever.
parts i have bought it
new driver side corner light
new none spray painted a/c vents
used valve cover
new timing belts/pulleys
new boost controller
new arp head studs
new head gasket
Here is a list of parts I need I will be glad to buy from any of you for the wright price
needs/wants
new coolant temp sensor
coolant temp pig tale
1g tps sensor
aftermarket header with dsm flange
front mount ic
a real brand name bov
gm maf with maf trans.
If you have any of the above parts shoot me a pm.
So is there any thing I need to know about these cars if I plan to make at least 500whp on stock block?
Do I really need to shave the balance shafts to make that kind of power? I rather keep it and it can keep the 5 little hp it frees up
Old Jun 16, 2011 | 09:15 AM
cjackson2802's Avatar
new temp sensor is $20...get a new one. for the temp sensor pigtail, just use a spade connector. if you're sticking to the dsm flange, get a 2g manifold and port the shit out of it, it flows fine and aftermarket isnt worth the money unless converting to t3 or t4. i have a 1g tps sensor, greddy type s bov, and the gm maf-t but i wont be able to sell for about a week or so. might sell my short route fmic too but idk.
Old Jun 16, 2011 | 11:35 AM
5.9FOX's Avatar
Thanks for the info. I definitely would like to buy all the parts you listed just let me know as soon as you can sell.
But im talking about the other temp sensor closer to the rad.cap, Thats the one i nee the clip for.
DrDirt
The Champagne Room
16
May 18, 2004 08:41 PM
Legato
Mazda Tech
35
Jun 20, 2003 06:14 AM
Rotary7
Feb 8, 2003 01:51 PM
celicagts04
Apr 25, 2002 11:49 AM
