Down side of TO large of a turbo. how to choose correctly.
Old Apr 25, 2011 | 06:49 PM
  #21 (permalink)
x8psycho8x's Avatar
haha. hopefully once the spare motor starts getting finished up it looks like I have plenty of people willing to help
94 accord vtec - traded
95 eclipse gs - blew up
95 eclipse rs - dd
Originally Posted by SayWhaa?
guess some of the guys shes sleeping with isnt too good with the whole pull out method..
Originally Posted by evlonedb
someone needs to tell her its a vagina,not a clown car!
Old Apr 25, 2011 | 07:24 PM
  #22 (permalink)
blackFLgst's Avatar
Probably $#%#ing broke.
Originally Posted by omgosh
About the log mani, its not that there is a point that its not ok anymore. Its just less efficient.
Ported.
REDLEG
13F
2010 Evo X GSR
Mods: 11's
Old Apr 25, 2011 | 08:48 PM
  #23 (permalink)
blacksti's Avatar
DudeMan
They create a lot of turbulence, and basically the exhaust has to fight to get out of the mani
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Apr 25, 2011 | 08:55 PM
  #24 (permalink)
x8psycho8x's Avatar
stupid question. do all tubular manifolds have equal length runners?
95 eclipse rs - dd
Old Apr 25, 2011 | 09:23 PM
  #25 (permalink)
ryu's Avatar
ryu
JUDGE RACING
No. For a small build like you are doing though, the cost far out weighs the benefits. With an Evo 8/9 16g, you will easily be able to hit your 350whp goal with plenty of room to spare.
Stock turbo/Stock Block- 10.80@125.97mph
FP Red/Stock Block- 10.301@132.93mph
http://www.youtube.com/watch?v=k2CqirgpFeM
Hta3582 w-.63Tial/Stock Block- 9.96@139.83mph
http://www.youtube.com/watch?v=rxjaKUnUZNk
Tampa's Quickest Mitsubishi
JUDGE RACING
Join us on Facebook
http://www.facebook.com/#!/pages/Judge-Racing/203463879689026
Sponsored by:
MAPerformance
Old Apr 25, 2011 | 09:36 PM
  #26 (permalink)
x8psycho8x's Avatar
that question was mainly because i was curious
it's not a small build it's my first haha need to start somewhere lmao
95 eclipse rs - dd
Old Apr 25, 2011 | 10:36 PM
  #27 (permalink)
omgosh's Avatar
Quoted from another forum..
Originally Posted by enthalpy and mattback
We (Myself and Mattback) built a car for a customer that wanted 500whp. Specs are as follows:
CP Pistons 9.0:1 CR
Stock Rods w/ ARP rod bolts
ARP Headstuds
Greddy Headgasket
HKS 264 Step 2's
RAS
Greddy valvesprings
Greddy Intake Manifold
Garrett GT3040R Turbo
ROM tune - Z32 MAF, 96# injectors
JGS Tools Log Manifold
HKS Intercooler
When we took it to the dyno for tuning all we could get out of the car at the wastegate pressure of 12.8 psi (0.9 kg/cm^2) was 300whp. I tried different AFR's and timing values but they yeilded no change. The setup simply would not make more than 300whp @ 12.8 psi. This was a problem becasue I knew that we werent going to get to 500whp without running stupid boost...which i didnt want to do. So after alot of head scratching and a few beers to help cope with the disappointment Matt and I compiled a list of everything that was different between this car and my car when it was running a nearly identical setup and making 340hp @ 10 psi.
This is what we came up with:
1) Log manifold vs. Full Race manifold.
2) ROM tune with MAF vs. Haltech on MAP.
At which point we looked across the garage to my car which is currently out of commission and decided we needed to try swapping manifolds. A call to the customer to discuss the situation...and he agreed it was the correct course of action. So the test was on!!
Matt and I worked dilligently friday night after work to get the manifold swapped over. We used my old downpipe and hot pipe of my car. These pieces were nearly identical to the downpipe and hotpipe that were on with the log...just slightly different fitments. We got it up and running, celebrated at Hooters for a late dinner...then headed off to the dyno on saturday morning. I was expeciting to see gains but we were unsure of how much. On satuday morning we ran the car at wastegate pressure (12.8 psi) and after a bit of tuning to get the new setup dialed in we saw the following gains:
All i can say is WOW...60whp and 35ft-lbs. Spoolup was almost identical with the Full Race hitting maybe 100 rpm later. I was completely floored by the results of this test. I was expecting 30-40hp maybe...but 60hp. I was totally shocked.
I think this also disproves the myth that MAF sensors are a restriction. this car made exactly what my setup made at 12 psi with a MAP sensor based system.
The truth of the matter is the flow properties of the LOG manifold are terrible. The flow from 1,2 and 3,4 directly oppose each other then are forced to do a hard 90 deg turn to enter the turbine housing. A basic understanding of fluid dynamics will tell you this is terrible for flow. The smooth transistions of the full race manifold make all the difference allowing the car to make more power even during spoolup!!
Thumbs up to the guys at Full Race for making such a quality product!!
Oh...and the car did 507whp @ 25 psi later that day!!
Old Apr 25, 2011 | 10:58 PM
  #28 (permalink)
blacksti's Avatar
DudeMan
Pretty much what I said in laymans terms
2jz mustang build
Old Apr 25, 2011 | 11:26 PM
  #29 (permalink)
omgosh's Avatar
gotta spell it out for tr
Old Apr 25, 2011 | 11:33 PM
  #30 (permalink)
blacksti's Avatar
DudeMan
If were doing this TR friendly, it should be a pop up book
2jz mustang build
