Throttle/ Fuel Issue
Old Jan 12, 2011 | 04:50 AM
Rich's Avatar
Old School.
Originally Posted by Krais
It's a NT 4g63. I replaced the wires, It sounded like it was miss-firing. This did not fix the problem. I think i need to get my fuel pressure checked..
So you read the code it was throwing? Sounds like MAF to me too.
You may know who we are, but we KNOW who you are.
Old Jan 12, 2011 | 09:55 AM
Krais's Avatar
One less bolt than you
Weirdest shit ever, I unplug the maf, Car idles PERFECTLY for the first time ever. Plug it back in and now it's fine. Must've had a shitty connection.
Old Jan 12, 2011 | 11:34 AM
omgosh's Avatar
lol. good to hear.
Old Jan 16, 2011 | 07:52 AM
wishiwasfast's Avatar
Check the wires going into the plug and or clean the MAF, so it doesn't happen again.
Originally Posted by RednekBubba
Just do the normal German torque spec "gudntite"
Originally Posted by 98EclipseTurbo
I have all of the rockers loose on my Intake cam and I believe the timing belt skipped and bent some valves when the harmonic balancer grinded into the valve cover.
Old Jan 16, 2011 | 09:29 AM
Krais's Avatar
Honestly, It's not the maf. Ever since i've had my car, it hasn't idled right. I never found out why. I'm now finding out, my cat was plugged. and all the back pressure blew the gasket from the exhaust mani to the down pipe, And the exhaust mani is now also cracked. So, it's my o2 sensor. Lol
Old Jan 16, 2011 | 05:28 PM
omgosh's Avatar
Yikes. Im always afraid of clogging my cat. Those gaskets before the o2 sensor make a HUGE difference, I had no idea.
Also, if you're still having rough start issues, check the coolant temp sensor. One of the wires on mine just broke and I thought of this thread. Same symptoms. It will start if I crank it just right. But then as soon as you tap the gas it dies. If you stab at it just right while the rshared_pm is rising you can "break through" it and rev the car up...still misfires like crazy till its warm though. So I unplug the MAFs and the car fires up...haha.
Old Jan 17, 2011 | 05:32 AM
  #17 (permalink)
Krais's Avatar
Lmao. Yeah. I started my car and heard an additional growling noise, I popped the hood and see the exhaust blowing out the side of the gasket. My initial thoughts were "Fucking awesome." lol
Old Jan 18, 2011 | 08:39 AM
  #18 (permalink)
cjackson2802's Avatar
would the o2 really make it run like that? im having similar problems now, and i know my maf is fine. lol my car randomly decides when it wants to start.
Old Jan 18, 2011 | 08:44 AM
  #19 (permalink)
which actually makes me think, one of my turbo bolts backed out completely and the gaskets leaking like a mofo lol
Old Jan 18, 2011 | 09:12 AM
  #20 (permalink)
Krais's Avatar
Yeah the cat can fuck it up, My car originally when i bought it, With the maf plugged in, I couldn't rev beyond 4k. UNLESS the maf was unplugged. And i tried fixing everything that would cause my car to do that, and idle awkwardly, Never even thought about the cat. Now my brand new downpipe gasket is blown and my exhaust mani is slightly cracked. If i even decide to fix it, I'm sazawing the cat off and replacing the mani. I've already got the muffler sazawed off so why not lol
