Quick question for you 4G63t peeps...
Old Dec 5, 2010 | 04:57 PM
OneCleanS14's Avatar
Default Quick question for you 4G63t peeps...
ok. quick question for you guys/gals. a buddy of mine has a evo I with a built engine, bored .020 over with eagle rods, CP pistons, 272 cams, evo 8 crank, with a hybrid super 20G turbo pushing 30psi. he keeps running a felpro HG and its blown on him. actually twice now in less than a month. now im not a mitsu guy, but wouldnt it be smarter if he ran metal HG from mitsubishi or something? thanks for any tips/advice.
KA-T.
Enthalpy Tuned.
Old Dec 5, 2010 | 05:45 PM
wishiwasfast's Avatar
Does it have at least ARP's? Yes, a metal head gasket would hold up better but both the head and block would need to be decked.
Originally Posted by RednekBubba
Just do the normal German torque spec "gudntite"
Originally Posted by 98EclipseTurbo
I have all of the rockers loose on my Intake cam and I believe the timing belt skipped and bent some valves when the harmonic balancer grinded into the valve cover.
Old Dec 5, 2010 | 05:59 PM
fitbikeco's Avatar
felpro are good if you have O-ringed head/block but if not be sure he using arp head studs or L19 and use oem MLS gasket from the dealer. The deck is prolly fine unless you see major grooves but the head may need to be re surfaced check them with a legit straight edge (not a ruler).
Old Dec 6, 2010 | 06:13 AM
EfWorld's Avatar
mitsu or just go with a strait up after market race HG
TR "Old Skool EF" Member #48
99 Mitsu Eclipse GS-T DD
91 Honda CRX Si
91 Honda Civic Si
91 Honda CIVIC Si FOR SALE da front brakes. mint interior, 650 buks
Old Dec 6, 2010 | 06:44 AM
DarksideZ's Avatar
TR Balla Donor Supreme
Originally Posted by fitbikeco
felpro are good if you have O-ringed head/block but if not be sure he is using arp head studs or L19 and use oem MLS gasket from the dealer. The deck is probably fine unless you see major grooves but the head may need to be re surfaced check them with a legit straight edge (not a ruler).
What the man said.
Old Dec 6, 2010 | 07:28 AM
DSM_Power's Avatar
hell to the yea! a metal head gasket from Mitsubishi would be the solution to this chronic problem! a 4 layer Metal HG from Mitsubishi would run u about $150 and you'd never have to worry about it blowing again.
Old Dec 6, 2010 | 11:18 AM
ryu's Avatar
ryu
JUDGE RACING
I ran over 46psi on my stock motor with the original OEM headgasket. Stick to the factory gasket, it's not a weak link.
Stock turbo/Stock Block- 10.80@125.97mph
FP Red/Stock Block- 10.301@132.93mph
http://www.youtube.com/watch?v=k2CqirgpFeM
Hta3582 w-.63Tial/Stock Block- 9.96@139.83mph
http://www.youtube.com/watch?v=rxjaKUnUZNk
Tampa's Quickest Mitsubishi
JUDGE RACING
Join us on Facebook
http://www.facebook.com/#!/pages/Judge-Racing/203463879689026
Sponsored by:
MAPerformance
Old Dec 6, 2010 | 01:56 PM
DarksideZ's Avatar
Yeah EVO metal vs. the 1g/2g felt gasket
Old Dec 6, 2010 | 02:28 PM
BeigeTsi's Avatar
Paul Walker
I hate to say this but I would stay with just a OEM non metal, because I agreed with Jerrys thoughts on a fuse like purpose, cause with the metal gasket the bottom end will go before the gasket does if something is wrong, at least with the non-metal you might me able to save your motor. And in terms of cost gasket is way cheaper than bottom end. But as the saying goes my 2 cents, but really its not my 2 cents just repeating what I agree with.
“It’s amusing to find that the road to success is never convenient however the road to failure all most always is...”
-S. Charles
"Excuses are monuments of nothing built by tools of inequity and those who use those tools will be masters of nothing"
-Unknown
"Time is a luxury that even the richest man cant buy"
-Unknown
1990 Talon TSi AWD
Joshua P.
Old Dec 6, 2010 | 07:14 PM
JR.'s Avatar
JR.
bad tuning will also blow hg.
98 talon awd automagic
