Advice for MS...
Old Jun 10, 2010 | 06:32 AM
  #41 (permalink)
CODE4's Avatar
Tig Welder/Fabricator
Originally Posted by x8psycho8x
MS IS IN AND WIRED!!!! after several hours and tweaking the tune and then finding some unsecured grounds the car fired up. throttle needs to be adjusted and it's idling at 2800 rpm's tho..
and question. has anyone heard on the MS misreading vac pressure? so far on the live feed the map isn't reading. it's saying my min & max is at 100. i'm sure john can chime in on what it's doing. he's been teaching me about the reading all damn night but he'll be able to explain it better. we're both stumped.
the car is up and running tho!!! i'm happy to hear it again
You have the correct MAP sensor selected in your config file?
TIG Welder & Fabricator
Old Jun 10, 2010 | 08:19 AM
  #42 (permalink)
john34683's Avatar
Hang out with my STANGOUT
yeah its set right, i checked it about a dozen times.
Frostbite- 95 mustang convert *SOLD*
Frostbite 2- 96 eclipse (custom) *SOLD*
Red Sled- 1989 Camaro RS *TRADED*
Bulldyke- 1981 K10 4x4 *RUSTY MUD TOY
Goatnutts- 1998 GSXR 750 SRAD *Traded*
Mario Kart- 98 civic ek w/ f22 swap *SOLD*
Lazarus- 90 Mustang LX Hatch *SOLD*
un-named- 86 trans am *SOLD*
Jailbate- 94 cbr 600 streetfighter *SOLD*
DD- 98 Astro
Michael- 87 camaro V8, 5 SPEED
Old Jun 10, 2010 | 10:30 AM
  #43 (permalink)
john34683's Avatar
at first (when we were having issues getting to to start) the MAP stayed at 11 or 12, we finally got it to start and it slowly started to creep up to 20 (even if the motor was not running). After we fixed some of the grounds it went up to 100 and stayed there while the car idled, under part throttle and even when we turned the car off.
DD- 98 Astro
Old Jun 10, 2010 | 10:56 AM
  #44 (permalink)
CODE4's Avatar
It should read 100 when the car is off. 100 = atmosphere (I assume you know this already though)
I believe it should read around low to mid 20s on a stock 420a at idle (assuming the rings are not wasted and the valve seals are good) - that was what I had back on my stock block.
Old Jun 10, 2010 | 11:05 AM
  #45 (permalink)
john34683's Avatar
but what is throwing me off is that it sits at 100 no matter if the car is running or not. we double checkled the vac line and everything.
DD- 98 Astro
Old Jun 10, 2010 | 11:51 AM
  #46 (permalink)
x8psycho8x's Avatar
yes the stock vac is right around 20 on a stock 420. john is right tho. i'ts 100 no matter what. and the vac line is clear, nothing blocking what so ever. and rings and seals have around 2k on them. i hope their not bad lol
94 accord vtec - traded
95 eclipse gs - blew up
95 eclipse rs - dd
Originally Posted by SayWhaa?
guess some of the guys shes sleeping with isnt too good with the whole pull out method..
Originally Posted by evlonedb
someone needs to tell her its a vagina,not a clown car!
Old Jun 10, 2010 | 07:08 PM
  #47 (permalink)
x8psycho8x's Avatar
ISSUE FOUND AND FIXED!!!!
the mep sensor in the MS wasn't sodered at all lol fixed it and the MS won't keep the car running now because it was basically tune reading atmosphere lol. pull the vac line and the car idles lol.
just need retuned now
95 eclipse rs - dd
Old Jun 10, 2010 | 07:25 PM
  #48 (permalink)
john34683's Avatar
thanks, now that you said "all it needs is a retune" we are now gonig to run into all kinds of other issues.....jack*ss
DD- 98 Astro
Old Jun 10, 2010 | 07:32 PM
  #49 (permalink)
x8psycho8x's Avatar
lol
95 eclipse rs - dd
Old Jun 10, 2010 | 08:24 PM
  #50 (permalink)
got_bst?'s Avatar
Passed you
if you wanna use the laptop again i'm off monday and tuesday
