brakes???
so all of a sudden when im slowing down to stop and start to applie the brake i herre a " CLICK CLICK CLICK CLICK" from the rear driver side it only makes the sound when the brakes are applied, i reached in and felt arount but every thing feels tight. its a slow clicking to, meaning if im at coast at 40mph or 5mph the clicking is the same, no faster no slower... any body had this problem..... i live in a apt so i cant just tear the car apart to look at it.... 95 gst
My friend said his was that his self adjuster or whatever for his rear brakes were loose, but he has drums for rear brakes.
But id check your lugs nuts to, but you should hear that contantly tho and not just while slowin down, but I'm guilty of leaving mine loose to
my ebrake is messed up i can pull the lever all the way up with no pressure, i looked at the adj nut in the center console and one side is pulled forward and the other is pulled back,, make sense?
now lift up the back of the car and pull your rotors off and your ebrake assembly will look just like a drum brake without a wheel cylinder. to me it sounds like one side is not retracting completely like if a spring is broken or something
THE PRICE IS WRONG BITCH!!!
