what would i need to safely build....
^ HIGH...My Name Is
on
a N/a 4g63 engine for boost... I just found a 94 eclipse gs for $1000, but im a fiend for boost.. how much would i have to lower the compression, and would i need aftermarket internals before I boost?? i kno injectors, fuel pump, and the headgasket but wat kind would lower compression enuf? For the record i havent purchased due to this lovely holiday, earliest i think i can get it iz monday..
pretty klean 4 a grand.
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Sure you can boost it. Internals are fine AS LONG as you dont run a lot of boost. I think 10psi on say a mitsu turbo would be the max. IMO. But im not 100% on that. and far as fuel system goes im sure your going to need something upgraded. car looks clean for 1k$ Good luck
yeah it depends on how far you want to take it. no more then about 10 or 12 pounds will be do-able. it would be better to buy a turbo model in the long run. IMO..
^ HIGH...My Name Is
on
shyt everyone has turboed their 420a's...i figure this could be a fun build for the price.....i heard you can use the manifold nd turbo from any 4g63 dsm u only gotta find the i/c and piping...and of course thats after compression is right and new injectors are on deck....
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
^ HIGH...My Name Is
on
and i was expecting to have to run ridiculously low like 4-7 lbs of boost....i think 10 is fine for a reliable DD build....
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
^ HIGH...My Name Is
on
will do...
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
please do not post links to other forums
Ok a turbo maxing at 8psi (even a TD05 with a 16g compressor) will spool at about 1800rshared_pm (already tested on my friends 94 gs, and worked perfectly), allowing for 13 and 12 second ¼ miles. (My friend ran a 13.23@104mph on this setup I created for the NT 1g carsat 8psi).
whats this
whats this
^ HIGH...My Name Is
on
thank you sir...i never go on that site, i obviously should
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
I don't really understand why my link I had posted was deleted. Seeing how this is a tech forum and you asked for help, I found a helpful solution and gave it to you.
whats this
whats this
