1g 7bolt compression
Old Oct 15, 2009 | 09:34 PM
omgosh's Avatar
Default 1g 7bolt compression
So I decided to compression test my motor today (found out my knock sensor had a broken wire ) and I came up with some weird results...
I got 180-180-178-179 , this is on what I believe to be a 1994 1g 7-bolt. I was under the impression that since it's a 7.8:1 motor that it should be closer to 160? I'm just wondering whats up with my motor. Maybe 2g pistons or something? JR told me the 1g 7bolts are 8.5:1 like the 2g motors...any one know for sure?
Found my info here How to do a Compression Test
Compression Test Vs. Leak-Down Test - DSM Forums
thanks
Old Oct 19, 2009 | 08:04 AM
THE_ONE's Avatar
*Turbo Interceptor*
That's normal with stock cams, about 175-180, you have to also take carbon build up into account.
A healthy 2g will read 190ish
Old Oct 19, 2009 | 12:20 PM
omgosh's Avatar
Thanks for the response...car was seafomed not too long ago so hopefully my motor is still "healthy". I do get a bit of valve seal smoke if I idle it for 10 minutes or so.
