98 gst map question
i have a 98 gst and i just put a 1g head tubular exhaust and a sheet metal intake on the car my question is on the manifold there is no spot on the intake where i can mount the map sensor. do i need to eliminate it and if so what do i need to do?
cheap, fast, reliable.......well i guess 2 out of three isn't bad
hell no dont drill a hole..... if you wamt to keep it, then invest. keep your shit clean and dont go drilling holes, that shit will never seal right and always be a possible boost leak.
EXTREME PSI : Your #1 Source for In Stock Performance Parts - JM 2G MAP Sensor Adapter: Mitsubishi Eclipse 95-99
buy this, mount it somewhere clean and convenient and be done with it. g/l
Look the way mine is set up is clean. All you have to do is take a vacuum line and plug it onto ur map sensor, a T fitting, and tee it into the line that runs to the BOV from the intake. Then all you have to do is tuck it. Perfect solution. If you need a pic I will take one.
GOT LOVE FOR THEM DSM'S
