small problems with my 2g
and how is it different from where it bolts to the o2 housing? he has a 4g63as long as the DP comes up to meet the o2 housing it can fit turbos a turbo
& All Grip Racing
& All Grip Racing
the routing of the exhaust piping is different on an AWD car than on the FWD cars....i'm not saying that it won't bolt up.....it will fit that way.....but it won't fit all the way to the rear bumper....
did u get my PM about the Valve cover and MBC???
lol there is like 10 of these trheads all with the same prob most of them cant go past 5psi
deff a boost leak
deff a boost leak
TR "Old Skool EF" Member #48
99 Mitsu Eclipse GS-T DD
91 Honda CRX Si
91 Honda Civic Si
91 Honda CIVIC Si FOR SALE da front brakes. mint interior, 650 buks
91 Honda CRX Si
91 Honda Civic Si
u would hear an exhaust leak even at idle unless u have a flew pipe that only opens up under boost, but even then you would hear it and an exhaust leak makes alot diff sound compared to a boost leak
91 Honda CRX Si
91 Honda Civic Si
91 Honda CRX Si
91 Honda Civic Si
Teein off of the BOV is not a good idea that can cause plenty of problems all on its own. Im guessing your running ur MBC off of that T. If you cant put a nipple on you J-Pipe try a different source off of your Intake Manifold
