2000 Galant Question for the Guru's
Old Sep 15, 2009 | 07:37 AM
  #21 (permalink)
enash99's Avatar
92 DSM AWD
Originally Posted by dsmturbo84
or even do a head swap
Evo 8 Head Swap Parts List
Model Part Name Part Number Qty
Eclipse 2.4L Head Gasket MD332035 1
Eclipse 2.4L Timing Belt Pulley MD156604 1
Eclipse 2.4L Timing Belt Tensioner MD308086 1
Eclipse 2.4L Timing Belt Tensioner Pulley MD182537 1
Evo 8 Adjustable Cam Gear 1
Evo 8 Cam Gear Bolt MF140285 2
Evo 8 Cam Gears MD322223 1
Evo 8 Camshaft Seals MD153103 2
Evo 8 Camshaft Sensor Housing MD344722 1
Evo 8 Camshaft Sensor Housing Cover MD329502 1
Evo 8 Camshaft Sensor Housing Gasket MD329503 1
Evo 8 Coil Pack Boots MD623073 2
Evo 8 Cylinder Head Rear Seal MD372348 1
Evo 8 Dipstick MD343884 1
Evo 8 Dipstick Tube MD342319 1
Evo 8 EGR Valve MR560582 1
Evo 8 Exhaust Cam MN143620 1
Evo 8 Exhaust Valve MD184078 8
Evo 8 Fuel Pressure Regulator MD320749 1
Evo 8 Fuel Rail MR561928 1
Evo 8 Head MN155744 1
Evo 8 Intake Cam MN143619 1
Evo 8 Intake Manifold MN137746 1
Evo 8 Intake Manifold Bolt MF241256 5
Evo 8 intake manifold bolt big MF241284 1
Evo 8 Intake Manifold Bracket MR560754 1
Evo 8 Intake Manifold Bracket Bolt MF140056 2
Evo 8 Intake Manifold Gasket MD310447 1
Evo 8 Intake Manifold nut MF430122 2
Evo 8 Intake Valve MD127840 8
Evo 8 Lash Adjuster MD377054 16
Evo 8 Lower Radiator Hose MN135593 1
Evo 8 Lower Timing Belt Cover MN143079 1
Evo 8 Oil Cap MN163112 1
Evo 8 Plug Cover MD345681 1
Evo 8 Rear Water Pipe MN143306 1
Evo 8 Reluctor MD375814 1
Evo 8 Reluctor Bolt MD368730 1
Evo 8 Rocker Arm MD375091 16
Evo 8 Spark Plug Gaskets MD186785 4
Evo 8 Spark Plug Wire Set MD343245 1
Evo 8 Spark Plugs MD374841 4
Evo 8 Thermostat Housing MN143307 1
Evo 8 Throttle Body MN128975 1
Evo 8 Throttle Body Gasket MD180361 1
Evo 8 Throttle Cable MN100169 1
Evo 8 Throttle Position sensor MD628074 1
Evo 8 Timing Belt MD326059 1
Evo 8 Timing Belt Front Cover MD334401 1
Evo 8 Timing Belt Rear Cover MD322517 1
Evo 8 Upper Timing Belt Cover MD373108 1
Evo 8 Valve Cover MN155455 1
Evo 8 Valve Cover Gasket MD340535 1
Evo 8 Valve Keepers MD016483 32
Evo 8 Valve Spring Retainers MN143698 16
Evo 8 Valve Spring Seats MD113424 16
Evo 8 Valve Springs MN158946 16
Evo 8 Valve Stem Seals MD306079 16
What a parts list, Thank you soo much. This will make it much easier.. But now i have another item to consider. I have someone with a mitisu starion. the 4g63t pretty much all stock, only wants 1200.. I might buy that..
Old Sep 15, 2009 | 07:38 AM
  #22 (permalink)
enash99's Avatar
92 DSM AWD
If I buy the Starion then i wont need to mod the galant. Unless for the same amount of cash I can get the galant rolling in the same range as the starion. And i have always luv the starion.
Old Sep 17, 2009 | 10:33 PM
  #23 (permalink)
99_Clipse_GS's Avatar
If your wanting a daily with some get-up, why not throw a small shot of nitrous at it?
whats this
