5speed swap
Old Jun 29, 2009 | 03:53 AM
Burton86's Avatar
Default 5speed swap
Hey guys seeing if anyone knows what it takes to do a 5speed swap, what will i need and what it takes, please if anyone has any info what so ever please help me out.
Thanks,Burton
Old Jun 29, 2009 | 06:57 AM
91TSI_AWD's Avatar
Resident Galant Guy
Little more info... what car? what year? what motor?
Mike
95 Lancer GSR
93 300ZX 2+2
Old Jun 29, 2009 | 07:00 PM
Burton86's Avatar
97 gst eclipse 4g63 5speed swap
95 gst eclipse 4g63 auto
Old Jun 29, 2009 | 08:28 PM
91TSI_AWD's Avatar
Resident Galant Guy
2G swap, other then the obvious tranny, clutch, pedal, hydraulics.... the 2G is going to have alot more electrically connected, your gonna have a shitload of Check Engine lights because OBD2 added tranny codes. Physically yes can be done and work, electrically your car wont be happy.
Mike
95 Lancer GSR
93 300ZX 2+2
Old Jun 30, 2009 | 04:44 AM
Burton86's Avatar
what if i get a 95 5speed ecu annd wire harness?
Old Jun 30, 2009 | 04:50 PM
Skyline Driver 5's Avatar
round and round it go
yea that will work i had to do that when i did a 5 speed swap in my 95. my ecu kept sending a signal to the auto tranny computer and it wouldnt go past 4k unless i was at WOT and that was only every now and then. take out the auto ecu and the regular ecu and put a 5-speed gst ecu. im not sure if the auto harness is independent between the tranny and its computer but check that too, it might give you problems but i doubt it. i hope that helps. good luck
TR "Old Skool EF" Member #150
Old Jun 30, 2009 | 06:50 PM
Burton86's Avatar
thanks. if anyone els has any info let me know it all will be helpful
Old Jul 2, 2009 | 06:04 AM
LuizHGato's Avatar
i had a 95 gst automatic, converted it to manual never had a problem with electrical. you'll have a lot wires sitting in your engine bay from automatic sensor, but you can get away with it, swapping harness. I still have my ecu eprom with dsmlink from my automatic gst.
Old Jul 2, 2009 | 06:40 AM
MITSUracer's Avatar
420a Do it UR-selfer
i have the trans u need if u want it
