car not starting
Old Jun 4, 2009 | 11:31 AM
BoostedTalon00's Avatar
DSMPowered
Originally Posted by MITSUracer
checked voltage is all good. and starter sounds fine and cranks at normal speed. just cant get it to turn over. must be something electrical.
I would def have to say if you're saying its cranking at normal speeds but not firing, check spark, if there's spark....check fuel components, I was cranking the gst for hrs trying to get it to start after a dissassembly, come to find out, the fuel pump wasn't plugged backed in under the seat cranked right up, but def check to make sure you're getting fuel and spark.
Old Jun 4, 2009 | 12:40 PM
MITSUracer's Avatar
420a Do it UR-selfer
ok so checked with stupid spark checker from advanced and didnt see any spark... so it must be the coil. went to napa cuz advanced didnt have it and napa wanted to charge me $130 of a coil!!!!!!!!! out of their fucking minds!!!!
and now im fucked. but it also might be the plug that goes into the coil....
Old Jun 4, 2009 | 01:11 PM
MITSUracer's Avatar
ok found that it is making spark!
the only other thing i dis connected was the TPS and IAC on the throttle body. do u think when i was gringind away at the TB i could have damaged one of the sencors? would the TPS or IAC not working keep it from starting?
Old Jun 4, 2009 | 01:58 PM
Evil_GST's Avatar
Pure Evil
Originally Posted by concordcobra
I found your problem...
Its a DSM
Correction, it's a neon
Old Jun 4, 2009 | 04:51 PM
MITSUracer's Avatar
lol well its the neon diff but i fixed it.
i retraced my stepps and un plugged all wires and cleand them up and reconnected them. started right up.
Old Jun 4, 2009 | 04:57 PM
Evil_GST's Avatar
Pure Evil
sometimes you'll end up bumping something loose and not realizing it. I do it all the time.
Old Jun 4, 2009 | 06:12 PM
  #17 (permalink)
DSMPowered
You workin on the eclipse? or I saw Neon? Either way, i dont think you can mess up either as the tps doesnt go into the tb, just sits on the throttle piece, and the iac, well it prolly sits too deep into the tb to even touch it, my guess is try ur fuel stuff, injector wires, fuel filter, fp, connectionsss.
Old Jun 5, 2009 | 06:56 AM
  #18 (permalink)
MITSUracer's Avatar
it was the eclipse, and it was just stupis plus not connecting
  #19 (permalink)
Super6's Avatar
santa fe pimp
it might be a loose nut behind the wheel
Old Jun 17, 2009 | 04:51 AM
  #20 (permalink)
.Patrick.'s Avatar
Has twenty valves
Zing!!
