turbo help
Old Jan 24, 2009 | 03:12 PM
clipse235's Avatar
FOR SALE
Default turbo help
im turboing my 420a ....wat all do i need besides turbo, front mount, o2 housing, piping, n BOV? i dnt plan on running anthing over 7 lbs of boost till i build the engine so i just need the basic don get all fancy pls....n yea i kno its a 420a i dont care if ur gonna talk shit dont write anything at all
Old Jan 24, 2009 | 05:00 PM
pure_power65's Avatar
Gone!!!
you are going to need oil feed lines also and a boost gauge, turbo manifold. good luck with it. have anymore questions just ask. ill be happy to help out!
& All Grip Racing
Old Jan 25, 2009 | 11:43 AM
Neesan's Avatar
EL RIPPO
Probably need some kind of AFC since your stock MAF might get angry. Maybe at least some 450cc injectors?
< Forged internals with squirters stock. 14psi proof. It WILL be turbo'd, just not anytime soon.
Old Jan 26, 2009 | 06:00 AM
dipstyc1928's Avatar
16g
i would recoment apr head studs and a metal head gasket since you're already there.
THE PRICE IS WRONG BITCH!!!
Old Jan 26, 2009 | 06:35 AM
fallen4ng31's Avatar
Cogito ergo sum
RS/GS models dont use a MAF, they use a MAP sensor. You'll need an FCD or a missing link to keep the MAP from seeing boost. 450's won't work without a resistor pack. 7PSI can be achieved with a 12:1 FMU on stock injectors, (Cheapest) but you'll need a Walbro 255HP model fuel pump. Also your injectors will be nearing 80-90% duty cycle with a 12:1 increase in pressure. An SFMU is more ideal, then you can utilize 450's with a resistor pack and run a little more boost. (Provided you're not using OEM internals.)
You'll need an oil feed / return setup. You'll need to weld a bung in to your oil pan for the return. You can tee off of the OPSU location for the feed.
Obviously things like a turbo manifold, BOV, boost gauge, aftermarket oil pressure gauge / sender, and EGT gauge (I cannot stress this one enough.) Wideband is always nice, but at 7PSI you can forego it if necessary. Unless you're planning on an SFMU and 450's; As it becomes necessary at that point.
An AFC is a moot point at that level; If you're going to tune it either go with Megasquirt or a PortFueler.
"Kid, If you call me 'bro' one more time, I swear to Christ you're going to find out what your left testicle tastes like."
I offer professional computer / network services and consulting.
Over 10 years of industry experience.
A+/Network+/Security+ Certified ; CISCO CCNA, Novell CNA, Microsoft Certified IT Professional.
Old Jan 26, 2009 | 07:41 PM
16g
i don't know if you'll run into this problem like i do but you'll also need money
boost is like a good whore. it's expensive but you want to keep hitting it
Old Jan 28, 2009 | 09:42 AM
clipse235's Avatar
FOR SALE
ok ima have 16g turbo dump pipe n manifold this friday...ima have o2 housing ,wastegate, fmic ,BOV n piping in 2 weeks any kno a good place to get the oil feed lines? n does it matter what size wastegate i have? and is 7 psi gonna be ok on my stock internals until i start to build i dnt plan on running it until then either..
Old Jan 28, 2009 | 10:32 AM
specVmatt's Avatar
400hp club, barely
lol you were being an ass before anyone even had the chance to be one for you. so.. dude its only a 420a!
Coyote
Old Jan 28, 2009 | 11:26 AM
blackFLgst's Avatar
Probably $#%#ing broke.
^+1
REDLEG
13F
2010 Evo X GSR
Mods: 11's
Old Jan 28, 2009 | 03:03 PM
Evil_GST's Avatar
Pure Evil
I personally would NOT run a metal head gasket on that car with a stock bottom end. it's better to blow a head gasket then destroy a bottom end. something has got to give, a head gasket is the fuse.
