turbo help
Old Jan 29, 2009 | 08:17 PM
Neesan's Avatar
EL RIPPO
Originally Posted by Evil_GST
I personally would NOT run a metal head gasket on that car with a stock bottom end. it's better to blow a head gasket then destroy a bottom end. something has got to give, a head gasket is the fuse.
Word, I wouldnt run one period. Unless you are 110% sure the head and block are flat or if you pay to get them decked.
ARP's smashing the shit outta the composite FTW!
< Forged internals with squirters stock. 14psi proof. It WILL be turbo'd, just not anytime soon.
Old Jan 29, 2009 | 08:20 PM
Neesan's Avatar
EL RIPPO
Originally Posted by fallen4ng31
RS/GS models dont use a MAF, they use a MAP sensor. You'll need an FCD or a missing link to keep the MAP from seeing boost. 450's won't work without a resistor pack. 7PSI can be achieved with a 12:1 FMU on stock injectors, (Cheapest) but you'll need a Walbro 255HP model fuel pump. Also your injectors will be nearing 80-90% duty cycle with a 12:1 increase in pressure. An SFMU is more ideal, then you can utilize 450's with a resistor pack and run a little more boost. (Provided you're not using OEM internals.)
An AFC is a moot point at that level; If you're going to tune it either go with Megasquirt or a PortFueler.
Sorry man, I dont know dick about the 420a's, Ive just seen snapped rods from them that look like some shitty cheap cast china recyled scrap metal. I was trying to throw out there some common knowledge that his car wasnt going to mesh with a turbo as easily as he wanted to do it in his opening post, just tryin to point out it wasnt just a turbo, exhaust, and a BOV like he wanted to do with out getting all "fancy". But good info, thanks.
To the OP: Bottom line, even if you were to sneak by and get the bare minimum (doing everything right so you dont trash your shitty rods that a person could snap in there hands) look to spend a good amount of $$$$$$$$$$$$.
Old Jan 30, 2009 | 08:42 AM
clipse235's Avatar
FOR SALE
would it be cheaper n better to just run a 75 shot with cams n headers?
Old Jan 30, 2009 | 08:54 AM
specVmatt's Avatar
400hp club, barely
cheaper, certainly not better.
Coyote
Old Jan 30, 2009 | 09:23 AM
clipse235's Avatar
FOR SALE
i jus wanna beat my friends LS lol
Old Jan 30, 2009 | 11:29 AM
blackFLgst's Avatar
Probably $#%#ing broke.
^lol.....seriously?
REDLEG
13F
2010 Evo X GSR
Mods: 11's
Old Jan 31, 2009 | 12:44 PM
  #17 (permalink)
clipse235's Avatar
FOR SALE
lol unfortunatly ...
