dsm help
i'm still new to this dsm thing i'm just asking for help i was wanting to know what is better i got a good handle on the 6 bolt swap but i read about some people using a 4g64 block with a 4g63 head what is going on here???
Correct that would be a 2.4l stroker engine. Nasty combo but can be a pain in the a$$ to time correctly.
If your interested in a stroker, you would be better off to use the 4g64 crank in your existing 2.0l block. You will then need to order pistons for a 2.3l stroker and get to work. There really doesn't seem to be a noticable difference between the 2.3l and 2.4. The 2.3 is just less headachs and goes together like a normal 2.0l
correction... the 2.4block with a 2.3 head isnt a stroker motor... just because your changing the head your not changing the stroke... also its not hard to time ive done it on my car and had no problems... the hardest part is plugging the 5unused oil holes on the block... many people use the soda can and jb weld but its not right you need to tap them and have a pipe fitting insterted to block the holes... another thing is wiring for the cas... need any more help of any info let me know ill help out... i had no problems dd my car and making 575 on a crap as turbo...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
hp~5!! trq-4!!
doing work!!!!!!
the timing is a little bit more of a PAIN to do then a normal 2.0 for most
All the rods are the same length. Just need to order a set of rods for a 2.0l turbo. It fits all applications depending on yr 4g63. Obviously you wouldn't order 6-bolt rods for a 7-bolt. The cranks are enterchangable between blocks and so are the rods. The pistons are different and need to be ordered according to the stroke of the engine you are building.
