bov question help
Old Nov 11, 2008 | 09:20 AM
  #31 (permalink)
damnDSM's Avatar
oak
I went through a real greddy typeS and a knock off typeS before I bought my 1g BOV. Both the knock off and the Greddy leaked.
The Greddy that came on the car had exactly 10k mi. on it when I bought the car. I didn't know it was leaking until I got DSMLink and I started monitoring airflow. I did a few boost leak tests and I couldn't find anything. So I bumped the PSI up and it pushed the valve open on BOV. Then, the knock offs diaphram split 3 weeks after I installed it.
I hear the SSQV knock offs aren't as bad, but you must recirculate them (like mentioned before, HKS sells the recirc kit) They each sound a little different, videos of each can be seen on youtube.
My advice;
Sell the knock off then buy a 1g BOV, and call it a day. When you are ready to run more boost all you have to do is "crush" it. Crushing the 1g bov compresses the spring that holds the relief valve closed. It simulates a firmer spring, and is the equivilent to the <---Hard Soft---> screw on some Blow off Valves.
1g BOV can be bought new from Mitsubishi for around $100 but used ones can be found for less than $20. "DodgeGarage" modified a 1g BOV and they are running 30psi with a little crushing and a single drill hole.
Old Nov 11, 2008 | 02:55 PM
  #32 (permalink)
lorijuan1024's Avatar
yea thinking of staying auto dont need the turbo to spool up every gear shift
but i am looking for a 1g with the thing you put it on for my ssqv
Old Nov 11, 2008 | 06:23 PM
  #33 (permalink)
Needfstwheelz's Avatar
^ HIGH...My Name Is
i have a 1g flange if thats what you mean...
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
Old Nov 12, 2008 | 06:18 AM
  #34 (permalink)
i dont know what i need lol
Old Nov 12, 2008 | 09:06 AM
  #35 (permalink)
^ HIGH...My Name Is
how about ill sell you the upper i/c hardpipe with 1g bov on it for 30 plus stock ic piping...if anything u might need some new couplers but ill hook it up for you..the pipe and elbow are red...
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Old Nov 12, 2008 | 10:01 AM
  #36 (permalink)
slowy's Avatar
13.04@104mph
Originally Posted by Needfstwheelz
i had to pull over to let the bov close properly.
do WHAT???
i would think releasing the throttle and idling should do the same thing......
Old Nov 13, 2008 | 05:31 AM
  #37 (permalink)
send me pic or post
Old Nov 13, 2008 | 05:50 AM
  #38 (permalink)
^ HIGH...My Name Is
Originally Posted by slowy
do WHAT???
it is the same feeling as bov being slightly open...throttle response goes down until the car comes to a dead stop and then you can do it all over again..i dont really kno if thats whats happening but i kno it only happened with type rs
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Old Nov 13, 2008 | 06:04 AM
  #39 (permalink)
i think my last eclipse had a type rs sounded lik it i know it wasnt recirculated it never did anything like that to me
Old Nov 13, 2008 | 06:06 AM
  #40 (permalink)
^ HIGH...My Name Is
here they are....
and paint is scratched in some spots...if you want i can give you the paint too and you could do it yourself...
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
