bov question help
Old Nov 3, 2008 | 06:36 AM
  #21 (permalink)
lorijuan1024's Avatar
dont plan on changing boost yet but will mods effect it that dont have to do with the turbo
Old Nov 3, 2008 | 07:57 AM
  #22 (permalink)
blackFLgst's Avatar
Probably $#%#ing broke.
dont sell it. buy a recirculating fitting for a hks ssqv. Don't get a type S you'll sound like a fucking bird going down the road. SSQVs are MUCH better than a type S. If you want something that works just as fine as either of them and holds just as much boost find a cheap 1g dsm BOV. They sound better and cost MUCH MUCH less.
REDLEG
13F
2010 Evo X GSR
Mods: 11's
Old Nov 3, 2008 | 08:12 AM
  #23 (permalink)
will the 1g bov fit right in or do i have to also buy the other parts too?
Old Nov 3, 2008 | 03:47 PM
  #24 (permalink)
Needfstwheelz's Avatar
^ HIGH...My Name Is
need a flange...or you could cut a section out of stock pipe...use couplers to connect the flange section i have...on part of a stock 2g ic pipe. I know a 1g bov bolts right on, thats how i bought it...using 1g bov currently
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
Old Nov 10, 2008 | 07:39 AM
  #25 (permalink)
MightyMaxGS-T's Avatar
ok well i can only speak for myself but on my starion motor i converted the maf to a 1g maf and i ran a greddy type s with no issues with atmospheric blowoff, you just can't have the bov adjusted loose like a freakin skittle. also instead of just stepping on the clutch and letting the car roll, you have to let the car decelerate in gear until the rpm gets around 2k and then step on the clutch.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Nov 10, 2008 | 07:02 PM
  #26 (permalink)
dipstyc1928's Avatar
16g
i'm running an hks ssqv and it's not recirculated. and i have no problems. just like mightymaxgs-t said, let the car decelerate in gear. don't just slam in the clutch or throw it in neutral. that will cause the car to shut off while driving.
THE PRICE IS WRONG BITCH!!!
Old Nov 11, 2008 | 04:19 AM
  #27 (permalink)
but mine is auto will i still have the problem
Old Nov 11, 2008 | 04:22 AM
  #28 (permalink)
16g
i'm not sure. just swap it to 5 speed so you know you wont have that problem
Old Nov 11, 2008 | 04:25 AM
  #29 (permalink)
^ HIGH...My Name Is
for once it seems only i kno this from xperience...his car is auto like mine...so vented is going to kick your ass unless you dont plan on passing the speed limit....I told you I had a type RS and it sounded sick, but our cars cant take that seeing as we cant switch gears when we want. I was doing 120 on 75 one day, and as i came up on traffic i decided id slow down...release the throttle and my car went crazy it started bogging down like crazy and i had to pull over to let the bov close properly. i kno you dont wanna have to do that everytime you go fast and decide to slow down...1g bov is what i have now and i havent got any complaints. Except I still sound like a bird going down the street...A big ass bird!!
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Old Nov 11, 2008 | 04:26 AM
  #30 (permalink)
^ HIGH...My Name Is
No Swap!!
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
