broke some studs in the head, how do i get them out?
down time man. i cannot have my car sitting while i LEARN how to remove and replace a head and do a timing belt and wait for the machine shop
vfaq had a write up on this. I used it for one of mine once and it worked like a charm.
Visual Frequently Answered Questions - Home Page
yeah
Untitled
but he just uses a 'drill bit'
i understand the concept of drilling in, using something else to turn the stud. the problem is that i can NOT drill INTO the stud
Untitled
left handed drill bit always does the trick
I have no trouble getting studs out. Very important to drill in center of stud. If it goes off center you are screwed. head will be junk. I use dremel to grind small spot first. then use 1/8th bit. they are black bits that come on red cards. milwalkee or still cant remember. then use the square shaped easy outs.
my favorite quote
my favorite quote
