420a head problems, where to get it fix
99 eclipse rs been blowing lots of greyish smoke from the exhaust without stopping, took it to some mechanic, told me that the valves seals are broken, said it would be $550 to replace em since doin that job would require usin the air compresor and all of that wich i know its tru, but i'm wonderin if anyone know a place where i could get a better deal to get the job done, or what other options i have, any help is appretiated
NEW VIDEO
http://www.youtube.com/watch?v=SkMyN_ZLgxA
NEW VIDEO
Do it yourself if you can, if not; Valve seals are around $25; But 5 hours of labor is a bit steep. I thin you can find someone to do it for around $350 if you look enough. Most mechanics go by the "big book of labor." More often than not, This book is quite wrong; after all, it is just a guide. A skilled mechanic can usually do a VS job in about 3 hours or so.
no to all the questions, the smoke isnt as bad when idling, but when u rev up the engine or take the car for a spin the results are that video i uploaded, took it to the northgate mechanic by waters and florida and they told me that when u dont move the car for a while the valve sea;s harden and then they brake or some like that, then they told me how much it would be to get em fix, and that meanwhile the car was gonna run fine and all just to check the oil every once in a while, then on the recipt it says "NEED VALVE SPRING OR SEAL" i think i'm gonna run the compression test, to be honest i dont know much about the engine, so does anyone know any good cheap mechanic around town?? been offered and recomended to buy a new head, would that fix my problems?
Correctly Diagnose your problem first (or get it diagnosed). Just throwing parts at it is going to cost you extra time and money.
