98 eclipse spyder wiring harness diagram
Old Aug 15, 2008 | 08:36 PM
mikiemike75's Avatar
mikiemike75
Default 98 eclipse spyder wiring harness diagram
i am tryn to find a wiring diagram for the ecu plugs i need to know what pins some wires are... does anyone know if the 2g turbo'd and non turbo have the same pins i know some things wouldnt be used but anyhow any info will be repped i need this asap ive got a 64 with a 63 head and i need some info on the cam angle sensor wiring... thanks guys
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
Old Aug 15, 2008 | 09:20 PM
Tom N's Avatar
Non DSM.....DSM guy
I dont know if there the same or not but here is a 2g turbo pin out 2G Turbo ECU Pinouts
Tom
Old Aug 16, 2008 | 10:26 AM
quadzilla's Avatar
The cam and crank pin numbers are the same at the ecu for the turbo and the SPYDER ONLY!! .So the link tom posted is correct.
"Sit right here pimpin,let daddy holla at ya,Now daddy can do this ALL DAY, EVERYDAY,NO PROBLEM". MAKE A PIMP DECISION
