did i miss anything?
ok i think i have everything covered,but wanted to ask if anyone sees something i missed.This is my DD.Goals are able to handle 650WHP BUT tuned to about 400/500WHP
1997 GS-T spyder
Engine
1991 4g63 6 bolt
wiseco .020 over
eagle H beam esp rods
ACL bearings
ARP piston bolts
ARP cradle bolts
knife edged crank
full cometic gaskets
balance shaft eliminator kit
ported and polished head with 3 angle valve job
cometic MLS head gasket
hks 264 I/E cams
AEM fuel rail
550 injectors(rc 1000 cc on the way)
flow matched intake and exhaust
c.o.p. (coil on plug)
msd ignition
FPR
GM maf-t
greddy FMIC
complete hard pipes
blitz bov
dnp tube exhaust
B16G
3" turbo back(no cat)
o2 dump
k&n filter
255 fuel pump
5/16 SS braided fuel lines from pump to inline high flow filter to fuel rail
MBC
ARP head bolts
SS intake,exhaust and valve cover studs/nuts
ERG block off
emissions removed
full rotating assembly has been 0 balanced and spun balanced to 9000rpms
A/C removed
trans
5 speed TRE stage 2 with shot peen service and quaffie lsd
fidenza 8lb flywheel
ARP flywheel bolts
grip force 2600lb clutch
suspension
kyb 4 way adjustables
skunk 2 coil overs
front upper tower brace
rear lower brace
wheels/tires
stock 16" wheels
riken raptors 205/55/zr 16
inside
boost gauge
A/F gauge
dsmlink
EGT gauge
misc
battery relocated to the trunk
fuel pump rewire
slave restricter removed
short shifter
shifter bushing upgrade inside and under hood
a/c and radiator rewired to work together
so thats it on my build,all machine work done by Carl's Machine Shop.If anyone sees something i missed please LMK.
1997 GS-T spyder
Engine
1991 4g63 6 bolt
wiseco .020 over
ACL bearings
ARP piston bolts
ARP cradle bolts
knife edged crank
hks 264 I/E cams
AEM fuel rail
msd ignition
FPR
GM maf-t
greddy FMIC
complete hard pipes
blitz bov
dnp tube exhaust
B16G
o2 dump
k&n filter
255 fuel pump
MBC
ARP head bolts
ERG block off
emissions removed
A/C removed
trans
ARP flywheel bolts
suspension
skunk 2 coil overs
rear lower brace
wheels/tires
stock 16" wheels
inside
boost gauge
A/F gauge
dsmlink
EGT gauge
misc
fuel pump rewire
short shifter
I i were you i'd get a better FMIC, the greddy piping is 2.5 youd be better off with 3 inch piping. Look into a ETS kit or something along those lines. You know your gonna get literally NO traction right? especially with your A/C removed and battery relocated.
Oh, and get atleast 680cc injectors, your gonna be all over fuel cut with a 16g and 550s
no plans for racing at all,i just wanted a solid daily driver with a good bit of pick up and MPG.and i agree with the pipe,seemed a little on the small side to me as well.550 injectors too small for say 450 whp?Thanks for the input.
550's are usually ok with a 16g, but 400whp your really going to be squeezing everything out of that turbo and going to need the extra fuel.
what kind of A/F gauge?? I'm assuming you mean a wideband, if thats the case I would think about swapping the EGT gauge out with maybe fuel pressure gauge.
Alcohol injection will allow you to squeeze alittle more power out of that setup.
I'd say that 400-500whp will have plenty of "get up and go"
+1 on bigger injectors and FMIC. If it were my I'd get some bigger cams but the 264s should easily support your goals
you forgot the part about where you go AWD...
+1 on bigger injectors and FMIC. If it were my I'd get some bigger cams but the 264s should easily support your goalsyou forgot the part about where you go AWD...
10 sec street truck...
awd conversion took me 1 week to do, not bad.
anyway, with dsmlink, get 1000cc injectors. go get an hta 30r or 35r, you wont hit 450hp on the big 16g. even if it was an evo16g it would take race gas or alky. pump gas your looking at 300-330 hp on that turbo.
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
1990 GS-T
