ever seen an eagle rod snap?
Did You Hit The Rev Limiter On That Pull
Impressive failure
No signs of heat or rod knock - Looks good prior to the failure.
The bearing will be slightly smashed if it was caused by a methanol failure. The rod broke at its weakest point.
I agree with Tom on this one.
They are just far more people with eagles so you hear about more failures.
well this engine has seen a good bit of knock before mainly from when my fuel pump went out, and there were signs of knock on the number 3 bearing(i think it was from previous runs though) methanol failure is pretty unlikely since i just bought a new pump 2 days before this, and i was keeping an eye on the boost and a/f when it happened.
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
soryy to hear about your misfortune. ooh can you send me a log also? Thankss..
Built 2.0L
ECMLINK
E85
BW S300ETT
& This GS-T hooks
All Built & Tuned by yours truly
In The Garage
- 99 Gst
- 91 Auto Talon
- 95 AWD TSI
& The DD,
a 07, S40 T5
Built 2.0L
ECMLINK
E85
BW S300ETT
& This GS-T hooks
In The Garage
- 99 Gst
- 91 Auto Talon
- 95 AWD TSI
& The DD,
a 07, S40 T5
Dane lol did you mean for the log to be only 5.4 seconds?
Built 2.0L
ECMLINK
E85
BW S300ETT
& This GS-T hooks
In The Garage
- 99 Gst
- 91 Auto Talon
- 95 AWD TSI
& The DD,
a 07, S40 T5
Built 2.0L
ECMLINK
E85
BW S300ETT
& This GS-T hooks
In The Garage
- 99 Gst
- 91 Auto Talon
- 95 AWD TSI
& The DD,
a 07, S40 T5
crap wrong stuff
ok heres the latest one i have..i never saved my other logs so this one is kinda in the middle of tuning. also the wideband input to the ecu was not working, dont mind the 13:1 afr
Srqspeed.com
-Dane
