Help! Overboosting...
Old Nov 22, 2007 | 06:46 AM
ddillard424's Avatar
Default Help! Overboosting...
i just installed my hallman boostcontroler last night and i switched to the heavy spring and with the boost controller as low as it would go im hitting 25+ pounds of boost.... i didnt hold it, i just notices it when iwas trying to hit stock boost. i put the light spring in and it did the same thing.. i have the vacume line coming off the wastegate to the 90 degree nipple on the MBC and the vacume line from the BOV to the other nipple on the MBC. theres no leaks anywhere. and i know my boost gauge is accurate...
Any help and/or insite to why its doing this?
<img src=http://i67.photobucket.com/albums/h296/SortaRican07/sig.jpg alt= class=post_inline_image loading=lazy />Ported & Polished Manifold - Megan O2 Housing`-`Megan Downpipe`-`Megan Test Pipe`-`Greddy Ti Exhaust`-`ETS Intake`-`ETS UICP`-`ETS LICP`- ETS 3''FMIC`- HKS SSQV BOV`-`Walboro 255 Pump`-`Hallman MBC`-`ACT Clutch & Flywheel`-`HKS Turbo Timer`-`AEM Boost,Oil & Wideband`-`Tanabe GF 210's`-`Labonte ISG-10 Meth Kit`-`Arp Head Studs
4WS TUNED!
Old Nov 22, 2007 | 08:26 AM
cyloc's Avatar
TR Shop Mod
The Pressure line(BOV or NIPPLE on lower intercooler pipe) should go to the bottom nipple on the hallman. The waste gate goes on the side nipple. IF this is how you have it then you got it on right. Check the MBC for blocks and make sure the spring is in correct. If the spring gets caught on anything internally the ball inside can get stuck shut.
JUDGE RACING
Old Nov 22, 2007 | 08:27 AM
Tom N's Avatar
Non DSM.....DSM guy
Do you have the nob screwed all the way in or all the way out.
Tom
Old Nov 22, 2007 | 08:31 AM
cyloc's Avatar
TR Shop Mod
^^ Good point forgot about that part...^^
JUDGE RACING
Old Nov 22, 2007 | 08:36 AM
its all the way out... i have checked inside and the ball and spring shouldnt be getting caught on anything... and i have the lines the right way... wastegate to side nipple on MBC and BOV/manifold line to the top nipple...
4WS TUNED!
Old Nov 22, 2007 | 08:37 AM
Tom N's Avatar
Non DSM.....DSM guy
If you take the mbc off and just run a vaccum line from the bov strait to the wastegate what happens?
Tom
Old Nov 22, 2007 | 08:42 AM
i have no clue, im going to meet up with cyloc in a little while to see if he can help figure out whats goin on.. if we cant ill run the vac line from the BOV to the wastegate and see whats going on
4WS TUNED!
Old Nov 22, 2007 | 03:12 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
can you run a line straight from the intake manifold? i dont think the nipple on the BOV puts out any pressure.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Nov 22, 2007 | 04:21 PM
slowy's Avatar
13.04@104mph
he said he's using the BOV line, not the nipple.
i have my profec setup
T'd off the bov line going to the profec box
line from the profec box going to the wastegate
works for me
Old Nov 22, 2007 | 04:40 PM
cyloc's Avatar
TR Shop Mod
DDillard just wondering if everything is OK. Never got a call to meet up.
T-ing of the BOV line works on the EVOs, but it is better to use the pressure line off the lower pipe. It gives you a better source of pressure for the boost controller. When you T-off the Bov line you have to share the pressure between the MBC and the BOV. This can cause the BOV to lose pressure and give you a boost leak. Using the pressure line from the lower gives you consistant pressure everytime, and gives each thier own pressure source.
JUDGE RACING
