Engine mounts
Old Feb 21, 2001 | 04:53 PM
BoostedRS's Avatar
I can freeze time
Help guys!!!!! It seems that if I go reverse and hit the gas I would hear this loud clanking in the bay. I would even hear it lightly on and off during a stop. I just had the engine mounts fixed and all at a local shop about 3-4 months ago and Ive only started to notice this a few weeks ago. Is there a way to see if it is the mounts? Is there a way to reinforce the mounts with aftermarket bushings etc...? I have a bad CV and I meant to get it fixed but I know that CVs dont make a clanking noise during a stop and when U mash the pedal in reverse. It just feels abnormal when I hit the gas on the green and it seems like my engine is about to jump out of the bay feels like Ive lost a bit of pick up too!!!! I would much rather be informed than to go to a dealer and be blindsided with a huge bill not knowing that they may have just tighten a nut and took 10 minutes to do it. I drive a 99 eclipse RS any help will be greatly aprreciated!!!!!!!
Olympus Evolt E-510, E-520, E-30 x 2
11-22mm f/2.8-3.5 Zuiko Digital
14-54mm f/2.8-3.5 Zuiko Digital
35-100mm f/2 Zuiko Digital
50-200mm f/2.8-3.5 ED SWD Zuiko Digital
Cybersync wireless trigger
FL-36R, FL-50R, Metz-48, and Vivitar 285HV x 3
Old Feb 21, 2001 | 08:41 PM
M&M's Avatar
M&M
You might want to check and see if the mounts are tightened down properly. If your car is a 99 why dont you take it in to the dealer for warranty?
Manny 97 GS-T
Old Feb 21, 2001 | 10:11 PM
M&M's Avatar
M&M
Honda guys break engine mounts all the time due to the tremendous amounts of torque they produce so Honda owners are excellent diagnosers of broken motor mounts. Heres how you do it. Youll need a friend.
Get in car start it put it in first gear pull the E brake up tightly. pop the hood and prop it securely. While your friend watching the engine bay try to slowly take off (heavy clutch slipping) in 1st gear then reverse. If your motor mounts are broken the engine will move quite a bit. If not youll probably just put some extranious wear on your clutch and possibly stall it.
If its an automatic...dunno what to tell you man...
Manny 97 GS-T
Old Feb 22, 2001 | 12:20 AM
BoostedRS's Avatar
I can freeze time
Thanks a lot for the help guys.....
Old Feb 22, 2001 | 11:54 AM
Mr 2's Avatar
New Member
for an automatic use the same method as john said just watch the engine as you are shifting into drive or reverse....
Thats Mr. to you
95 Eclipse GS-T
89 MR2 NA
-Eric
Old Feb 22, 2001 | 12:00 PM
BoostedRS's Avatar
I can freeze time
Do u guys know how much moving foreplay the engine does when checking it??
Old Feb 23, 2001 | 02:38 PM
Mr 2's Avatar
New Member
your engine will move a bit with good or bad mounts but with bad mounts it will make a clunck noise and will move more suddenly and not very smooth looking......take a look at someone elses car that has good mounts to see how smooth the engine moves back and forth to get an idea then try it with yours
Thats Mr. to you
95 Eclipse GS-T
89 MR2 NA
-Eric
Old Feb 23, 2001 | 08:09 PM
BoostedRS's Avatar
I can freeze time
Thank you so much for the help guys!!!!
