GM MAFT help
Old Aug 11, 2007 | 05:19 PM
fitbikeco's Avatar
Default GM MAFT help
I just put in my MAFT and 3in Gm MAF I dont know what to set the settings at im tuned with An S-AFC and i was told you just set everything on 0 can some one help me with this
Old Aug 11, 2007 | 06:03 PM
TrboANTsi's Avatar
FL,..gods waiting room!!
nope, i have hte instructions somewhere in the garage. go to
http://www.fullthrottletech.com/atta...1&d=1151351071
those are the manuals for the 2g. dunno if that what you have but you dont just zero it out really.
Old Aug 11, 2007 | 06:19 PM
fitbikeco's Avatar
i have a 1g and i was told to set AUX on 0 and BASE on 2 cause i have 550 injectors and everything else on 0 cause im uing an AFC
Old Aug 11, 2007 | 06:36 PM
TrboANTsi's Avatar
base is supposed to be set at the base setting for a stock car. not the injectors you have now..i have my set to the 450s even though i 660s and my car idles fine. FULL THROTTLE SPEED - Store Front Page theres a lnk for the 1g too.
Old Aug 11, 2007 | 07:27 PM
fitbikeco's Avatar
ya setting BASE 2 is 450s and i have it set their and i start it and it runs fine for about 10 sec then it just starts dieing
Old Aug 11, 2007 | 07:33 PM
TrboANTsi's Avatar
did you connect the wire to the rpm signal? i forgot what color.
Old Aug 11, 2007 | 07:53 PM
fitbikeco's Avatar
the white one yes and i jusat put a gm maf from a running car on it and it still runs good at idle but when you hit the gas its like nothing is their
Old Aug 12, 2007 | 05:20 PM
GsT Racer's Avatar
back in a 4g63
i dont think you can just plug it in and go, it needs to be tuned. i know with the gm-maf setup you dont need afc anymore.
Old Aug 12, 2007 | 06:05 PM
fitbikeco's Avatar
so your saying you cant set it all settings at zero like idle,mid and WOT even if your using afc
Old Aug 13, 2007 | 08:00 PM
Jap's Avatar
Jap
VTEC Out
As I told you 0 everything out and start driving around and looking at the wideband and turn the knobs till you get it decent ..
AFC should just be sued to fine tune it
Hondata saves lives
