spyder engine swap
Old Jul 26, 2007 | 03:55 PM
LuckyHB94's Avatar
Default spyder engine swap
i've done a search and all i can find is stuff about the 4g63t not being able to swap into a 420a car but what about swaping it into a spyder with the 4g64? i have a 96 gsx with body damage and was thinking about swaping the awd parts onto a spyder. i have read about the swap and know what it takes but i need to know if i could use a gs or if it would have to be a gst.
Old Jul 26, 2007 | 06:28 PM
50TRIM's Avatar
It would have to be a GST or Spyder. The 420A mounts are way off. The 4G64 is similar in the block setup as the 4G63 even though it is a single cam. The are a few differences but you can use that block for a 4G63 head with some minor modifications. You would be left with a stroker motor in the end. The 64 has a longer stroke than the 63. But, your best bet is the 64 in the spyder, and use the 63 head.
www.gearracing.com
