Eclipse Wont Start! help plz
Old Jul 4, 2007 | 02:51 PM
Buri3d's Avatar
Default Eclipse Wont Start! help plz
I have a 97 Eclipse gs. I replaced the starter a few weeks ago and it recently went out again a few days ago (the selinoid was faulty, happens with rebuilds). Now I put a new starter in and the car still wont start, I know the starter is good I had the store check it. I've made sure there is power running to the starter and its grounded, checked all fuses, battery is fine, and I'm not getting a "check engine" light. The engine isnt even trying to turn over. Any advice guys? I'm at a loss on this one.
Old Jul 4, 2007 | 03:09 PM
Figs's Avatar
If you look on your firewall on the drivers side. There's two solenoid looking squares with plugs that go into them. Tap those while starting the car. You can also unplug them and plug them back in. Sometimes it's that causing the no-start issue. I would try that.
I was told long time ago its usually the cause of a no start. They should be right above your brake resevoir or close to it.
If that doesn't work, check for spark. Check your plug wires and coil pack... make sure they are plugged in real good.
Also, when you turn the key do your hear the fuel pump priming or no?
Old Jul 4, 2007 | 06:38 PM
Buri3d's Avatar
ok thanks, I will try that tomorrow. Is there a certain place I have to be to hear the fuel pump? I dont think I hear it, I really hope I dont have to buy a new one of those!
Old Jul 4, 2007 | 09:26 PM
96neonmike's Avatar
being sideways=anti-drug
hey if it dont start after all that ill buy the car have a motor ready for it
Old Jul 5, 2007 | 03:13 AM
JR.'s Avatar
JR.
crankwalk
98 talon awd automagic
Old Jul 5, 2007 | 01:18 PM
Figs's Avatar
You should be able to hear it inside the car just by turning the key ON/ACC not trying to start the car. Sounds like a buzzing sound for only a few seconds.
Go to 2GNT.com and ask the same original questions you asked in the beginning of this thread. Those guys there should be able to help you since they have the same 420a based cars as you. You could also find information there by just searching "won't start" or phrases towards that aspect.
Old Jul 5, 2007 | 03:39 PM
Neesan's Avatar
EL RIPPO
Originally Posted by qbanjr9
crankwalk
Right on.
< Forged internals with squirters stock. 14psi proof. It WILL be turbo'd, just not anytime soon.
Old Jul 5, 2007 | 03:42 PM
Buri3d's Avatar
Ah the buzzing sound, yes I hear that. HAHA crankwalk? its a 420a motor, And no thanks I love my baby I wouldnt sell her, at least not till a RX7 comes along.
Old Jul 5, 2007 | 04:34 PM
Figs's Avatar
Something is either disconnected or loose. Especially if you say the battery is fine and the starter is grounded correctly and has power. The starter should turn when you turn the key unless you have a short somewhere. Check all your connections again. It still could be a bad ground. Is the starter making any noise when you try to start the car?
Old Jul 5, 2007 | 05:00 PM
XMasta19's Avatar
Drunken posting pwns me..
Your starter isn't even engaging, thus the car not even cranking. If either of the relays on the firewall (ASD and fuel pump) weren't working, the car would crank and crank but not start. I bet if you jumped the battery power terminals and ground on the starter, it would fire right up. If that's the case, then you simply need to track down the open in your starter circuit. Are you sure all of the fuses and fusible links are good? Did you simply look at them, or did you verify their condition with a multimeter?
EDIT: If you have a dmm, then it's very easy to figure this out. First thing I would do is check if you have 12v at the starter power wire from the battery. Verify the ground is secure as well as the signal connection that might have popped off or loose.
-Xavier-
Last edited by XMasta19; Jul 5, 2007 at 05:05 PM. Reason: ...more wonderful troubleshooting information!
