boost setting?
Old Apr 18, 2007 | 09:38 AM
GNEn!st's Avatar
AWD all the way
Default boost setting?
I got a 14b on my ride and was wondering whats a good boost setting for it. Right now im running 15psi.
mods: intake, 3'dp, 3' full exhaust no cat, ported manifold, greddy type s bov, hallman mbc, safc
let me know what you guy think
Old Apr 18, 2007 | 04:11 PM
Todd's90's Avatar
0711, USMC
15 psi on a stock fuel system?
1990 GS-T
1990 GST
2004 BMW 325i
Old Apr 18, 2007 | 04:44 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
i would put a wideband on there to know where youre really at and you can tell if you can handle more boost that way.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Apr 18, 2007 | 05:01 PM
GNEn!st's Avatar
AWD all the way
thanx i was just wondering if i could turn it up, i got a 16g at home and just wating for the my fuel pump and fuel pressure reg.
Old Apr 18, 2007 | 05:07 PM
Todd's90's Avatar
0711, USMC
I would think 15 would be high on a stock fuel system. what kind of FPR are you going to be running ?
1990 GS-T
1990 GST
2004 BMW 325i
Old Apr 18, 2007 | 05:10 PM
NEWBORN240sx's Avatar
Turbo Dave
my friend ran 24psi on a stock fuel system.... you just got to look out for fuel cut
Old Apr 18, 2007 | 05:15 PM
Todd's90's Avatar
0711, USMC
Old Apr 18, 2007 | 05:32 PM
THE_ONE's Avatar
*Turbo Interceptor*
^^ Not necessarily BS, I've seen it done, not the smartest thing to do but has been done. The limit I would like to say is 22psi safely if boost cut doesn't hit. The 1g is more forgiving when overboosting, I would atleast put a walbro fuel pump in and you will be fine. My X ran 20psi on a 14b and no issues. It now has a 16g on it at 15psi and is running rich. I will be turning the boost up to 18psi to see if it balances out.
Old Apr 18, 2007 | 05:38 PM
Todd's90's Avatar
0711, USMC
what car did your "friend" have? a 1g or 2g ?? what turbo?
1990 GS-T
1990 GST
2004 BMW 325i
Old Apr 18, 2007 | 05:41 PM
THE_ONE's Avatar
*Turbo Interceptor*
He had a 1g with a 14b
I also did it on a 1g with Walbro and a mitsu Garrett -24/14b custom turbo from Dave at Majestic Turbo.
My GSX has a walbro 255, FMIC, and when it had a 14b I ran 20psi, I will more than likely be there again with the small 16g thats on it now. I wouldn't dare go higher than that without bigger injectors and safc hooked up. With the 14B it would hit 20psi and drop down up top to 18-19psi and hold! I also have a potientiometer in the car which should make it run leaner but it seems to make the car run richer. I also run a 6-bolt 1g engine in my 2g
