boost setting?
For the record, he can run 15-16psi on the stock pump
I ran 15 pounds on my stock pump at one point and the car ran like shit, it ran better at 10 pounds. at 15 it felt like it was knocking all to hell so I backed it out to 10. definitely get a fuel pump, they are pretty cheap, easy to install and will give you much more room to play with
Hey man if you can afford it, I would pick up a set of Evo injectors too, there cheap.. $120-$150 You can never go wrong, it will be great to high boost with your 16G when you put it on!
I have a set of 680's and an SAFC that I was going to put on my car, but I can't seem to get what its worth so I'm done putting money into it
1990 GS-T
