throttle body control valve vaccuum line
Old Apr 17, 2007 | 12:15 PM
loserspearl's Avatar
rageman
Default throttle body control valve vaccuum line
I have a '98 mirage with a 4g64 swapped and I need help!
ok here's the dealio, I put on a new throttle body and I'm sure this is some sort of throttle control valve and I don't know where the vaccuum line goes, my car won't idle (it had the same problem before this new thottle body) and I think this is the problem. The wierd thing is this valve wasn't on my old throttle body. My whole vaccuum line and electric setup to the intake manifold is correct with no open lines (except this) and I can't just splice it from another vaccuum line because it just opens to full throttle. I think it is suppose to go into my vaccuum control valve (next picture) but there are only 2 lines coming from with a plugged third line (can't unplug it) Do I need to get a new vaccuum control valve that has the third line for it? If not what can I do to have my car idle correctly?
lady RAGE
Old Apr 21, 2007 | 04:25 AM
Figs's Avatar
Only thing I can recommend is find an Eclipse with the 4g64 and take a look under the hood.
