Loud Noise coming from the Bottom end
Old Apr 10, 2007 | 05:44 AM
T!CO's Avatar
DSM/4G63
Well today is my day off im about to drop down the oil pan to see waza up....i will maintain inform....
T!CO
Old Apr 10, 2007 | 07:17 AM
Flaco_GST's Avatar
Master of the cut-off T'S
Dude sucks to hear, hope it works out. I would call the brother's.
...Only god can judge me...
"If you don't set goals for yourself, you are
doomed to work to achieve the goals of
someone else."
Women might be able to fake orgasms but us men can fake a whole relationship.
V-TEC = Virtually-Torqueless Economic Cars
(PROG) Crew member #5
{o,o}
|)__)
O RLY?
Old Apr 10, 2007 | 07:28 AM
Todd's90's Avatar
0711, USMC
clean your oil pan real good, then drain it, if you find small pieces of metal in the oil then you know right off the bat that it could be a bearing. just so you know what to expect when you do drop the pan
1990 GS-T
1990 GST
2004 BMW 325i
Old Apr 10, 2007 | 10:02 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
Originally Posted by Todd's90
who said he was'nt running a cas? don't worry T!co, you have a cas.
he meant CAM angle sensor
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Apr 10, 2007 | 12:20 PM
Todd's90's Avatar
0711, USMC
thats funny, wen I read it I did not even pick up on the fact that he typed crank in stead of cam, I figured he was talking about the cam angle sensor.
1990 GS-T
1990 GST
2004 BMW 325i
Old Apr 10, 2007 | 05:18 PM
Todd's90's Avatar
0711, USMC
so ...? what did you find?
1990 GS-T
1990 GST
2004 BMW 325i
Old Apr 10, 2007 | 05:21 PM
  #17 (permalink)
awdsal's Avatar
dsm fever
thanks dane
Old Apr 10, 2007 | 07:37 PM
  #18 (permalink)
T!CO's Avatar
DSM/4G63
Well guys i drop the oil pan down, i didnt find any metals pieces at all, but since i was down there i took all 4 rods and i check one by one and as well the # 2 bearing was all broke. i replace and i just had a hard time getting the oil pan back but i was almost done and start raining like a middle of a hurricane, anyways i hope it was that and the crank didnt get mess up, otherways i will need to take the all motor apart and rebuild it..... i hope in GOD with the new bearings my problem will be fix....
T!CO
Old Apr 10, 2007 | 09:01 PM
  #19 (permalink)
BOX SENTRA's Avatar
OG MUDBONE 240sx
i was referring to this post cause i think he meant he could wire up a 1g cam angle sensor to eliminate the crank angle sensor which crankwalk destroys. (you can eliminate the crank angle sensor on a 7 bolt block right? correct me if im wrong)
Originally Posted by awdsal
it will run a little longer if you had a cas
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Apr 11, 2007 | 05:52 AM
  #20 (permalink)
Todd's90's Avatar
0711, USMC
so you replaced just the bearing??? if the crank did not look to messed up then you could be in the clear, I had a buddy with the same issue and the crank was indeed all messed up but he just replaced the bearing anyway and his car still ran for another 20k miles or so before he got rid of it. keep us updated.
1990 GS-T
1990 GST
2004 BMW 325i
