it has begun
no, you cant have my muffler lol. i like it WAY too much.
and not too much longer, everything is ready for installation, i got all of the mounts in for the gastank, subframe, and driveshaft. any welding and cutting is done, now is just a matter of bolting everything up. if i worked on it for 2 days i could probably have it about done.
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
mounts for subframe are in place, and gastank has been mounted.
now i gotta mount the subframe, transfercase, and driveshaft. should be ready to go after that.
Srqspeed.com
-Dane
i plan on having it put together before friday. im hoping thursday should have it done, im just having trouble taking the diffs apart, thats the only thing holding me back. im gonna mount the subframe tomorrow and worry about putting the diff on later. maybe thursday ill have the diff on. tomorrow i gotta go to the hardware store and get bolts for the driveshaft and transfercase. and get all the fluids i need.
Srqspeed.com
-Dane
so, the subframe is bolted in, youll notice that there is no diff, driveshaft or transfercase. well, i have to get the internals swapped from the 1g 4 bolt diff into my auto diff since the cases are different. i dont have the tools to do it, so im going to bring it to jerry and run it fwd for a few days. i still need some bolts for the transfercase too, so thats whats holding me back a little bit. and i would have had it on the ground today, but one of the brake lines broke at the metal hardline part, so i have to repair that somehow.
Srqspeed.com
-Dane
