weird howling noise.
Old Feb 3, 2007 | 08:27 PM
eclipse4eva's Avatar
Default weird howling noise.
alright tonight sucked. my oil filter came off and it sprayed oil everywhere....on all the body panels on my car and everthing in the engine bay. after we got the oil filter put on there again the car drove fine...but after a while...it wouldn't boost at all
and whenever it tries to boost i only hear this howling/whistling sound...it won't go over like 2 psi.
all the intercooler piping seems to be in place too..
what could cause this?
Old Feb 3, 2007 | 08:31 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
turbo is gone. sound like a ghost right?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Feb 3, 2007 | 08:41 PM
BoostLogik's Avatar
BoostAddict
Yeah, sounds like the "death whine". Double check all your ic pipes though, make sure they are tight. Check for any splits or rips if you have the factory piping. Also, double check to make sure your blow off valve is totally secured and tightened down to its flange.
Blow off valves (usually the stock ones), can pop out of their flange and sit loosely, when they are not tightened down securely. What will happen is your boost will rush out of the hole where the flange is, and cause a "howling" sound as well. I was working on my car one time, and I removed my HKS blow off valve. When I put it back on and went to drive, I got a loud howling sound, and the car wouldn't build boost, so I turned it around, back to my house. I popped the hood, and realized the blow off valve popped out of the flange, so I stuck it back in there and made damn sure it was as tight as I could get it. Problem solved. (of course, the plastic I/C piping sucks in the first place, so hard pipes are a good investment, along with a good quality FMIC).
Keep your fingers crossed and pray it's a leak of some sort...otherwise, hope you get a good tax return and replace that compressor.
"Even through the darkest days, this fire burns, always"
Old Feb 4, 2007 | 05:50 AM
2g's Avatar
2g
Could be the turbo is gone. This happened to me when some of the fins broke on the 16g I had 2 yrs ago. It howled real loud only boosted around 1-2psi.
I would do what BoostLogik said. Start looking for any leaks especially around the bov and if all those are secure then the turbo could be the problem.
Old Feb 4, 2007 | 07:23 AM
alright well today morning i started her up and for like the first 5 mins it was still doing that howling sound...and then it boosted to 10lbs fine and didn't make the sound??
why would it just go away like that?
Old Feb 4, 2007 | 07:56 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
hahah i wouldnt question it...dont mess with it, if it works, screw it!
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Feb 4, 2007 | 08:18 AM
to clarify..while it was making that weird sound..it made a loud pop noise...and after that it boosted fine without the noise...was it maybe clogged up or something?
i'm just worried that the turbo might blow while driving and then i'll be stuck for another 3 hours on the side of the road.
Old Feb 4, 2007 | 10:55 AM
AnthrAxNSB's Avatar
first
Everything you describe (sans oil filter coming loose) is identical to my old '90 TSI (although, I don't recall the problem boosting). The pop, the howl, the spontaneous remission.
I don't know what caused it, and I never had the problem again.
Old Feb 4, 2007 | 01:47 PM
well it's still howling and when it does it's hesitating to boost..
also when i open my hood..i hear like knocking from my engine....
all this cause my oil filter came loose...
Old Feb 4, 2007 | 02:56 PM
another update: I removed the filter and checked the turbo...
it has a lot of shaft play...i can push it in and out for like an inch and then up and down like 1/2 an inch.
i still hear this weird knocking sound...it seems like it's coming somewhere from the back..near the throttle body.
