spark cut
what heat range plug are you using and how much boost
obviously try new plugs first, but what are the conditions of the missfire? rpm, only under boost?
I used to have problems with plugs backing out of the head which would cause misfire issues in that cyl.
Wires, plugs, coil pack, too rich via afc or bad fpr. Lots of things really.
