Compression Ratio's
Never Really understood the break down and the significance of the compression ratio numbers(8:5:1,8:8:1,etc). Also to which sercumstances do your run high or low compression ratios and what would be the pros and cons of such. And how do you go about choosing the best set up for your goals/boundrys.
Thanks
Joshua.
Thanks
Joshua.
“It’s amusing to find that the road to success is never convenient however the road to failure all most always is...”
-S. Charles
"Excuses are monuments of nothing built by tools of inequity and those who use those tools will be masters of nothing"
-Unknown
"Time is a luxury that even the richest man cant buy"
-Unknown
1990 Talon TSi AWD
Joshua P.
-S. Charles
-Unknown
-Unknown
1990 Talon TSi AWD
Joshua P.
theres more to it but to make it simple, lower ratios around 8 or 9 to 1 would be better for boosted aplications, higher ratios like 10 or 11 to 1 is better for n/a
in memory of Kevin Gonzalez 6/21/86 - 9/13/06
Would anyone be able to supply a link/book/article that would elaborate. Though there is "more to it" I would really like to have a good understanding of this topic as to better my knowledge and understanding not just this is this, that is that. Hopefully I will be able to decide in the end what is best for my set up. Knowledge is Power...horsepower
-S. Charles
-Unknown
-Unknown
1990 Talon TSi AWD
Joshua P.
-S. Charles
-Unknown
-Unknown
1990 Talon TSi AWD
Joshua P.
compression ratio is the volume of the combustion chamber when it is all the way at the bottom of the engine (bottom dead center) compared to the volume of the chamber when it is at top dead center.
more compression = more torque and better fuel mileage. if your compression is too high, you run into detonation (the charge being ignited before the plug fires) because compressing gasses heats up, in this situation to a temperature high enough to ignite them.
higher compression usually = more power, unless you run a lower compression ratio and more boost.
thats how i understand it anyway, some of that may be a bit off....gl
they also have to run race gas all the time or low boost, for an all out race car that is built right and for the track a higher ratio and high boost with race gas can make the most power but for daily driver dsm street cars on pump gas a 9/1 and around 20psi will get you safe and good results
i dont know of any links, but maybe try howstuffworks.com look up compression ratio and see what pops up
nevermind i looked and found this Compression Ratio - Page 1
GSt racer very good link
-S. Charles
-Unknown
-Unknown
1990 Talon TSi AWD
Joshua P.
-S. Charles
-Unknown
-Unknown
1990 Talon TSi AWD
Joshua P.
