what would cause.....
Old Nov 21, 2006 | 12:56 PM
Dain's Avatar
Yea I would work on adjusting it out. Catching with the pedal near the floor it no good in the long run.
The rod going through the pedal, you turn that to adjust it. Kind of common sense when you look at it. Just go up under your dash and check it out!
Old Nov 21, 2006 | 01:07 PM
dsmdreamer's Avatar
mine is a 420a...works the same?
Old Nov 21, 2006 | 01:23 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
yea i would think they all work the same for anything. turn the rod toward the master for higher engagement, and away for lower. youll grind if you have it set too low, and it will wear the the disc out if its too high. theres a locknut on the rod too, just loosen that and you should be able to turn the rod by hand, if not needle nose pliers will do.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Nov 21, 2006 | 07:24 PM
2gntTalon's Avatar
well i will be the first to say...... CRANKWALK! jk
Old Nov 21, 2006 | 09:13 PM
LS1Fever's Avatar
You beat me to it! If no one else said it, I was just about to.
Old Nov 21, 2006 | 09:16 PM
mitsu420aT's Avatar
i was waiting for some one to chime in on it.
thats why the capital letters about the clutch.
Old Nov 22, 2006 | 03:26 AM
  #17 (permalink)
DSMboost97's Avatar
How long will it last?
Definately be carefull not to set it too high, i just adjusted the rod on my friends del sol and went just a little too high but didnt know cuz i was pressed for time and didnt have a chance to test drive it. Needless to say it burned up the clutch pretty good. I feel pretty bad about it too so i think ill go play with it friday morning before we all head to the track.
Old Nov 22, 2006 | 09:03 PM
  #18 (permalink)
GsT Racer's Avatar
back in a 4g63
yeah i adjusted mine too high too. it was actually fine for a while after starting it up in the morning, but after a few shifts or so it would start to slip if i really got on it...and then it would feel weird... i would start it up and everything would feel fine, but after those couple shifts the clutch would engage as soon as I touched it, meaning it was already pulling apart as sooon as it moved half an inch. shifted beautifully though lol.
now i have it adjusted again to an irritating spot where it has to be all the way down. i have to shift to 4th and then reverse to go backwards, and it grinds then. then i have to shift 2nd to 1st in order to start moving forward, and it sometimes grinds then. then if im not paying super close attention, i misshift. very irritating.
Old Nov 23, 2006 | 01:15 AM
  #19 (permalink)
GoFast&Turn's Avatar
For anyone who might still have questions about how to do this:
Clutch Adjustment
Chris
